07-25-2019, 01:50 AM | #1 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
I did my first half mile
POver the 4th of July (late post I know) I went to a half mile event. Fortunately for me it was an extra "practice" day that they added last minute. There were maybe 15 cars in my session. We got 7 passes in. My car did a best of 154.6mph.
cool little mix of cars. 5gen zl1, gt500, ctsv, atsv, c5,6,7 vettes, gtr's, supra, a couple hellcat challengers including a red-eye that I wanted to line up with since we were close on trap speed. Overall a lot of fun and some really cool people and cars! I used my street set up for the event. Mmr m716 19". 285/35/19 pilot 4s up front and 325/30/19 pilot super sports in the rear. https://youtu.be/iZDzls7aSAg
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance Last edited by Dubchitts; 07-25-2019 at 02:05 AM. |
07-25-2019, 06:18 AM | #2 |
Did you have to start with cold tires (no prestage burnout)?
Funny how they used a flashlight to start like that Street Outlaws tv show lol. The 4-5 drop on the 6th-gen's M6 sure is nasty. They should have used the C6 ZR1 5th and 6th gear ratios instead I think. |
07-25-2019, 06:44 AM | #3 |
I've always wanted to try a 1/2 mile. Looks fun. Have you run the 1/4 mile with your car? I think I could run 170 mph or more. Wish there was a calculator for that. Congrats looks like you were kickin ass after you stopped spinning the tires.
07-25-2019, 08:57 AM | #4 |
Those are a blast. Nice numbers
07-25-2019, 09:23 AM | #5 |
No pre stage burn out. I dropped my rear tires to 30psi and then spun them a little off the line to put a little heat in them so they would grab on the 1-2. Launch doesn't really matter for the half. As long as your putting it all to the ground shortly after.
I usually run around 125 in the 1/4 If you can find one, I had a blast and everyone I talked to did too. Ours was part of an airshow that was going on so it was 3days of runs, plus my practice day that I was on. Usually you get 2 passes from what I hear.
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
07-25-2019, 09:26 AM | #6 |
Thanks! And thank you for having the only dry Roto-Fab I could find when they were switching to in house manufacturing!
"Spitfire" 427ci
07-28-2019, 04:26 PM | #7 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Nice numbers, Dubchitts. I've always wanted to do a 1/2 mile event. How was that GForce shaft at those speeds? Any vibration?
Baby Blue
07-28-2019, 04:54 PM | #8 |
I didn't notice any vibration. Everything felt really good
"Spitfire" 427ci
07-30-2019, 06:24 PM | #9 |
Good to hear. A loop, axles and driveshaft will be my next upgrades, followed shortly by wheels for the drag radicals and skinnies I picked up from Greg (laynlow)
Baby Blue
07-30-2019, 10:29 PM | #10 |
Nice runs, you gapped them cars hard. Pray FTW
2016 NFG 1SS A8
08-02-2019, 06:52 PM | #11 |
I was pretty happy with a "baby" stg 1 cam lol
"Spitfire" 427ci
08-02-2019, 06:56 PM | #12 |
Definitely recommend the loop and drive shaft. I almost pulled the trigger on axles this winter but decided (probably dumb thinking) I'd rather break the stock axles than something else. Hopefully it wasn't a bad call on my part lol
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance Last edited by Dubchitts; 08-03-2019 at 06:05 PM. |
