07-20-2019, 06:29 AM | #1 |
OEM? Whats that?
Drives: 2014 Camaro SS Black Widow Join Date: Sep 2016
Exhaust Cutouts
Anyone have exhaust cutouts? I wanna install some. Electric preferably. Any good brands? When I feel like being an asshole I switch out my Hooker Blackheart slip-ons for some straight pipes. SUPER LOUD !! Lol Id rather just buy some cutouts.
2014 Southern Comfort Black Widow SS LS3
Magnuson Supercharger, ceramic coated ARH headers w/cat deletes, BTR blower cam, Mahle forged pistons, AEM Methanol injection, JRE 8 rib Super tensioner, Innovators West 8 rib serpentine pulley system, Melling high flow oil pump, Lingenfelter high flow fuel pump, McCleod RXT ceramic coated Twin disk clutch, Hooker BlackHeart exhaust. Escort 360 radar detector & dashcam. Rockford Fosgate 1000w prime amp, 2X12” Rockford P3D2’s Build and mods done by R&D Motorsports in Baton Rouge Tune/Dyno done by ,,Engine Power Systems in Baton Rouge |
07-20-2019, 08:17 AM | #2 |
Drives: 2010 2SS Coupe; 2011 2LT Vert Join Date: Dec 2018
I did eBay cutouts... I spent $100 on the cutouts and $60-$80 for a muffler shop to weld them in (can’t remember exactly). I love being obnoxious when I want to be.
They work great but keep in mind they will all leak just a little. https://youtu.be/XIY07qtg4gA
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
07-20-2019, 08:56 AM | #3 |
OEM? Whats that?
They work good?
07-20-2019, 09:07 AM | #4 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
The deal is if you want electric they are going to burn out the motors eventually and some don't last that long as reported on here...… so IMO cheap may actually be better, and some spares might be wise...…..
07-20-2019, 10:51 AM | #5 |
OEM? Whats that?
What r some other options?
07-20-2019, 11:42 AM | #6 |
They work great so far. And if they burn out, no big deal. The motors are cheap as long as you stay away from the expensive ones like QTP. The biggest drawback is they leak a little, bit even the QTPs do.
07-20-2019, 11:30 PM | #7 |
Drives: 2013 Camaro SS Join Date: Oct 2016
I have QTP. They've been on for almost 2 years and I open and close them at least once a day without any issues.
07-22-2019, 07:44 AM | #8 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
I also have QTP's and use them every time I drive (not daily). I did have one of the stacked gears in the motor gear train chip a toof. That makes the controller iffy at times, but otherwise no big deal. A spare motor is only $67
07-23-2019, 08:40 PM | #9 |
OEM? Whats that?
I bought a pair of oval QTP cutouts with low profile tips and a QTP electric remotes.
07-24-2019, 06:30 AM | #10 |
Grumpy Grey-haired Guy
Drives: Camaro, Corvette & Merc C300(daily) Join Date: Aug 2014
I got some Noweeds a while back. They've been on the car for almost two years, no issues, well-made product, not cheap. It's debatable what makes me grin most, the noise when you dump the lot out each side or the whine from the Magnuson. In fact, it's prob the Noweeds. Wake them neighbours!
07-25-2019, 05:48 AM | #11 |
Drives: 2023 Camaro ZL1 1LE Join Date: Feb 2016
QTP.
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler 2023 Camaro ZL1 / 1LE Stock |
07-27-2019, 01:56 PM | #12 |
Drives: 2018 Camaro ZL1 A10 Join Date: Nov 2018
We have had a lot of success with QTP over the years. If you decide to buy a set, call us. We always have some kinda deal going on.
They make pretty much a direct fit system, which we sell here- https://www.cspracing.com/quick-time...-2l-v8/500110/ And they make the low profiles, which fit well, but require the shop to do more welding. https://www.cspracing.com/qtp-low-pr...al-kit/qtec66/ We also now sell Turbo Valve cutouts, which are kinda cool. They don't use electric motors, instead they use pnuematic turbo wastgate based valves. https://www.cspracing.com/turbo-valv...pair/amg-tv-3/ |
07-28-2019, 01:40 PM | #13 |
Drives: Nickey Super Camaro Join Date: Nov 2008
We have been working with No Weeds diverters for almost a decade. Never once had an electric motor failure, never once had a sealing issue. Can’t say this about any of the electronic motor brands. The noweeds are a very well engineered component. Yes, the initial cost is more, but value is high.
http://m.youtube.com/watch?v=XnoD_50...me_continue=63 Last edited by NicKey; 07-28-2019 at 01:50 PM. |
07-29-2019, 03:38 PM | #14 |
What he said...
QUOTE=NicKey;10582951]We have been working with No Weeds diverters for almost a decade. Never once had an electric motor failure, never once had a sealing issue. Can’t say this about any of the electronic motor brands. The noweeds are a very well engineered component. Yes, the initial cost is more, but value is high. http://m.youtube.com/watch?v=XnoD_50...me_continue=63[/QUOTE]
