Old 06-28-2019, 06:46 PM   #1
RCF
Drives: '17 2SS, NGM, MRC, DPP; '19 F150
Splitter vs stock SS air deflectors - which rub first?
Ok, so the air deflectors on my SS are tearing from rubbing when going up into and back out of my driveway. Pretty sure it happens when the car enters or leaves the driveway at or near a 45 degree approach angle.
I’ve always liked the look of the 1LE style splitters, but concerned it would rub on my driveway and be destroyed. Anyone know which gives the most clearance?
Trying to decide whether to get a splitter or replace the air deflectors (or not).
Thanks!!!
2017 Camaro 2SS, Nightfall Grey Metallic, Magride, NPP exhaust, VS Forged VS12s in brushed clear coat (20x9 front, 20x10 rear), Michelin PS4’s (255/40 front, 285/35 rear)
RCF is offline   Reply With Quote
Old 06-29-2019, 03:54 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Thanks!!!
I saw a picture once of someone who installed a splitter along with their factory air deflectors. The deflectors go further down but if you're having trouble right now I'd suggest to take your current deflectors off and see if it still scraps against the driveway. Might have to start coming in at more of an angle to avoid that. Or have someone spot you once when you come up to see how much clearance. I would totally buy the splitter and have that but be careful once installed.
Old 06-29-2019, 05:16 PM   #3
RLem619
RLem619's Avatar
Drives: 2019 Camaro 2SS A10
I have both on my car. Unless it's a very sudden, sharp incline, deflectors will rub first.
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
RLem619 is offline   Reply With Quote
Old 07-05-2019, 11:55 PM   #4
SSmash
SSmash's Avatar
Drives: Mosaic Black Camaro 2SS
Deflectors.
SSmash is offline   Reply With Quote
