05-27-2019, 12:53 PM | #1 |
Drives: 69 Camaro SS Join Date: May 2019
Strut Tower Cracked on 1LE
I was looking at a 2018 1LE Camaro for sale, and when I went to look under the hood I noticed the strut tower was cracked at the top where the upper strut is bolted up.
The owner told me he hit a pothole on the drivers-side, and he didn't notice anything until he looked under the hood and found the crack. I don't think this is a good thing.....the upper strut mount itself looks like its destroyed because the "bell shaped cone" is staying up higher than the right side. Take a look at the pics and tell me what you folks think. I was told that BMR makes a strut tower brace that can keep this part of the tower together, but I'm not too sure about that. Would you buy this car??? |
05-27-2019, 01:23 PM | #2 |
Drives: 17 Camaro lt, 22 Camaro LT1 Join Date: Nov 2016
I'd take a pass on that buddy. Its a structural part that if compromised in any way (cracks, rust, broken bolts, ect.) won't even pass a PA state inspection. It must of been a bomb crater to do that kind of damage! Might want to inspect the alignment, strut, and steering components for more damage.
05-27-2019, 02:08 PM | #3 | |
Drives: 2017 ZL1 Join Date: Jun 2018
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
05-27-2019, 02:40 PM | #4 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
The car is totalled, stay far away from it. The guy should call his insurance so they can write it off and tow it away
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
05-27-2019, 02:56 PM | #5 |
Drives: '18 2SS/EU (+Recaros) M6 Red Hot Join Date: Nov 2018
I agree, walk away from that one.
05-27-2019, 06:18 PM | #6 |
Drives: '19 ZLE, S54 E36M3 Join Date: Feb 2018
Some Porsche GT3 and GT4 models have similar issues with the cast aluminum towers, only they usually punch clear through, not just crack. It is fixable, but expensive, and certainly calls into question the car’s potential abuse. Keep looking, unless they are giving it away.
https://rennlist.com/forums/gt4/9483...r-failure.html |
05-27-2019, 08:58 PM | #7 |
Thank you Al Oppenheiser!
nope.
05-27-2019, 09:45 PM | #8 |
Who Needs to KNOW?
If it as mine, drill the root, weld it back - but as potential buy.. nope the F out.
ing for grip.
05-28-2019, 05:38 AM | #9 |
Liv'n The Dream!
Since it's a 2018 I'd be looking to Chevy to replace the entire car under warranty! I mean really! It's one year old and a main component of the unibody has failed! WTF. Don't just walk away, RUN!
Never be afraid to try something new. The Ark was built by amateurs and the Titanic was built by pros.
05-28-2019, 06:59 AM | #10 |
More like hitting a curb. I would have to think the tire and wheel were replaced too. Look for scrapes underneath
05-28-2019, 07:31 AM | #11 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
Not sure that I agree with it being warrantied... It's likely a result of impact, not a defect.. If anything, it should have been covered under insurance...
05-28-2019, 06:24 PM | #12 |
Thanks for all the input...I appreciate it.
I wonder what that tower is made from?? Aluminum / magnesium? Looks like plastic to me. It looks like that tower can be replaced...I see rivets around the perimeter of the casting. They can be bought from GM. Its called an Apron Assembly - GM (84372616). Any body / chassis shop guys dare to chime in? |
05-28-2019, 10:42 PM | #13 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
05-29-2019, 06:35 AM | #14 | |
