05-25-2019, 04:21 PM | #1 |
Drives: 23 2SS 1LE Join Date: Feb 2019
HELP! SD card lost in car.
Hey guys, so long I was getting my SD card from my dash cam when it fell, landed in front of the AC vents and then slid under them. Ive also had a credit card slide further in than I was expecting, thought I was going to lose that.
Id really like a way to get back there and get my SD card. What pieces do I need to remove to get to it? And yes you can see that I took the knee pad off but couldnt get that plastic piece behind it off, not sure what all is holding it in or if it even leads back there.
Instagram: RideWithDanger
Current Mods: Rotofab, Ported LT2 intake, LT5 TB, Kooks Headers, AWE Touring Catback Radiant Red 23' 2SS 1LE 1100: 11/14/22 | BUILT: 3/16/23 2000: 2/17/23 | 4200: 5/8/23 3000: 2/27/23 | 5000/6000: 5/15/23 |
05-25-2019, 04:35 PM | #2 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
Maybe use a toothpick to fish it out, or straighten out a paperclip?
05-25-2019, 04:36 PM | #3 |
Retired from Car mfrs....
Shop vac.....
05-25-2019, 04:38 PM | #4 |
Drives: Camaro 2SS & ZL1 Join Date: Mar 2018
Use a piece of paper, fold until long and thick enough topush it out one side. Put it I The opposite side and fish it through until it falls into the floor, keeping it at an angle so you hopefully don't push it through the back.
2017 Camaro 2SS A8 Bright Yellow NPP MRC
2023 Camaro ZL1 A10 Radiant Red |
05-25-2019, 04:41 PM | #5 |
Not sure if I completely understand what your saying. I had a tiny flat head back there and a piece of folded paper but I can't reach the SD card. It looks like there is a small drop off back there.
05-25-2019, 04:42 PM | #6 |
I'm pretty sure there is a small drop off. I have tried fishing for it but even using the flashlight I can't see the SD card at all.
05-25-2019, 04:43 PM | #7 |
376 cubic inches of fun
First, try using a dental mirror or similar to look into the gap. Hint: to illuminate the gap, put a mini flashlight as close to your eyeball as possible and point it at the mirror. Now the light and your line of sight will be nearly the same. Move the mirror around until you see down the gap.
Once you have spotted the card, use the shop vac. If that doesn't work, try masking tape looped over a thin steel ruler. Unless the card is jammed, a light touch of the tape should pull it out. Avoid jamming it further in...go slow. |
05-25-2019, 04:47 PM | #8 |
05-25-2019, 04:48 PM | #9 | |
05-25-2019, 04:56 PM | #10 | |
But for now, I think we should all get some black foam to stuff in there Sorry for shakey camera, at the beginning I tore off some paper about the size of a microsd and shoved it under, that is what I am getting out. Just wanted to make it quick in case you need the card immediately
05-25-2019, 05:30 PM | #11 | |
05-25-2019, 06:25 PM | #12 |
Well unfortunately that did nothing. I think the micro SD card has fallen further back there them a piece of paper could reach. Also having no luck with tape. Anyway I can take pieces off to get back there?
05-25-2019, 06:31 PM | #13 | |
You can try to remove the center console, here's a video about upgrading the wireless charging pad in the rear that shows you what to do:
05-25-2019, 07:22 PM | #14 |
Well, that was too much work but I found a short cut. If you pull the carpet out, theres a tiny little gap where you can stick your hands in and feel around. I felt the sd card and pulled it out.
But beware, I have pretty small hands and it was still a tight fit and kinda hurt my hand trying to pull it back out. BUT, I got it. Me: 1 Camaro: 0
