04-13-2019, 05:57 PM | #1 |
Drives: 2SS/RS LS3 NPP Join Date: Feb 2018
How bad is coin op car wash water?
The coin op car washes recycle the water (except for the low pressure final rinse I've read).
So how bad is it for the cars paint to use recycled water? I usually do waterless washes (apartment dweller), but occasionally it would make things easier with a high pressure pre rinse to knock off the dust. Thanks!
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
04-14-2019, 10:49 AM | #2 |
Obsessed
Drives: 2016 Hyper Blue 2SS RS Join Date: Jun 2011
I can't imagine there is anything wrong with it, but I am sure someone more knowledgeable will chime in.
2016 Hyper Blue 2SS |
04-15-2019, 02:14 PM | #3 |
Drives: Supercharged 2013 AGM 2SS/RS Join Date: Oct 2013
My guess is it's way safer than waterless washing for anything beyond light dust. When I lived in an apartment I used a coin op frequently to rinse of the car before a doing a rinseless wash back at home.
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports. 1967 Bolero Red 396 SS/RS Convertible |
04-15-2019, 03:46 PM | #4 |
Thanks!
04-15-2019, 05:41 PM | #5 |
Drives: Miss Con Ception Join Date: Aug 2016
I wouldn't drink it
Automatic washes recycle too. It is supposed to be filtered, of course.
Usually the water commission requires that, they can't handle the amount of water and waste otherwise. Ready-mix plants recycle the water (and sand and stone) from left-over mix, though I would be leery about washing a car with that.
2011 1SS/RS LS3 CGM
04-15-2019, 11:59 PM | #6 |
Drives: Camaro 1LE Join Date: May 2018
I've never seen anything bad with the car washes I use around my area. My thoughts are you're fine and have nothing to worry about but don't use the scrub brushes.
04-16-2019, 11:48 AM | #7 |
Instagram: Sangstah
I use coin op washes all the time, just never the brush, luckily mine has high pressure soap
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-16-2019, 12:24 PM | #8 |
Drives: Camaro Join Date: Apr 2019
Depends on the softener.
04-18-2019, 07:38 AM | #9 |
The water from the pay & spray car washes can leave water spots if left to dry.
If your just wanting to knock whatever loose contaminates on the surface before doing a waterless wash, that is fine. However a Rinseless wash would be a much safer option for your paint. The soap used at the Pay & sprays is generally cheap non ph-neutral, and will strip wax/sealant so I'd avoid it. Get yourself some good microfibers and a couple 5 gallon buckets with lids, and do a rinseless.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
04-18-2019, 09:01 AM | #10 |
Drives: 1991 Z/28 Convertible Join Date: Feb 2018
As long as it doesn't have brushes I would say you are okay.
