03-30-2019, 11:19 PM | #1 |
Drives: Grey Join Date: Jul 2018
Camaro V6 1le Rear Calipers
Does anyone know where I could get Camaro V6 1le Calipers for the rear.
I tried on going to GM parts direct but they don't have them anymore just the fronts. If you know a place or know someone getting rid of their rear 2 piston calipers. This information would be grateful. Thanks |
03-31-2019, 01:41 AM | #2 |
Drives: 17 SS 1LE Join Date: Dec 2015
Aren't they the same as the regular V6 calipers?
03-31-2019, 01:43 PM | #3 |
Drives: '18 1SS 1LE Join Date: Sep 2017
Thought they were the same as the base SS brakes.
'18 1SS 1LE Black, PDR
04-01-2019, 10:46 PM | #4 |
04-01-2019, 10:47 PM | #5 |
04-01-2019, 11:12 PM | #6 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
V6 and Turbo 1LE have single-piston, sliding calipers just like the none-1LE versions/other LS/LT cars.
All 6th Gen Camaros have the same electronic parking brake setup. You can use SS rear calipers. |
04-02-2019, 01:02 AM | #7 |
Drives: 2016 M6 2.0T Join Date: Nov 2016
Not true. The SS rear parking brake system is tottaly different than the V6/2.0. The SS isn't compatible with the V6/2.0.
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
04-02-2019, 11:09 AM | #8 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
Correct. To add more detail to this, the SS has a single park brake motor that pulls cables for the park brake inside the rotor hats. The sliding calipers have 2 park brake motors that are mounted directly to the calipers.
2017 SS 1LE.
04-02-2019, 12:21 PM | #9 |
So the V6 1LE only gets the SS front brakes, and retains the V6 rear brakes?
04-02-2019, 02:04 PM | #10 |
04-02-2019, 11:23 PM | #11 | |
Drives: 2018 1LS 1LE Join Date: Jan 2018
Technically it doesn't have the SS front brakes either. It has the 4 piston Brembos but uses 12.6" front rotors (321x30) instead of the 13.6" front rotors (345x30) that the SS uses.
Tags |
1lt brakes, brakes, camarov6, parts for sale |
