03-03-2019, 08:46 AM | #1 |
Tops of struts
My car has BC Racing coilovers on it. Should the tops of the struts be flush with the body or should they stick up a bit? My top parts are above the body.
03-03-2019, 12:31 PM | #2 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
Tops of struts
Pretty normal for lowered cars, mine are like that with 1” drop springs. There’s been other threads about this also and everyone said it’s normal.
Sent from my iPad using Tapatalk
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
03-03-2019, 12:48 PM | #3 |
Thanks.
03-05-2019, 12:20 PM | #4 |
Drives: Race Car Join Date: Sep 2009
Very Normal
03-05-2019, 12:39 PM | #5 |
Instagram: Sangstah
Yeah they are supposed to stick out like that so they can move around when suspension flexes.
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
03-05-2019, 01:20 PM | #6 |
Engineer
Drives: 2014 Camaro 2SS RS 1LE Join Date: Jun 2015
Normal, if you want to get rid of that you will have to switch to a camber/caster plate top mount
2014 Red Hot Camaro 2SS RS 1LE
-Sunroof Delete, Recaro, Nav, NPP -Pegasus Subframe Bushings, JPSS Radius Insert, Detroit Speed Caster Mod, PMAS Intake, Solo High Flow Cats, Ecsta PS91 Tires, MGW Shifter, Pegasus Offset Poly Diff Bushing |
03-10-2019, 07:51 AM | #7 |
It doesnt bother me the way it looks or anything. Was just making sure there was nothing wrong I have to worry about. Thanks for all the replies.
03-10-2019, 06:54 PM | #8 |
Drives: Camaro V6 Join Date: Oct 2016
I'd get the top plate. I'd feel very uncomfortable having the nut and threaded shaft mere millimeters away from the underside of the hood sheetmetal.
03-11-2019, 07:13 AM | #9 |
These Moreno Plates were one of the best Mods I did - allows for a perfect, and adjustable, vehicle alignment, specifically dialing in more Caster which you can't get with the stock set-up.
Aggressive Street settings are recommended based on an average drop of 1 inch: Front: Camber to -1.0 degrees caster 7.4 to 7.8 degrees (requires adding Pedders Caster eccentrics or CAMBER/CASTER Plates to get into this range of caster, which is very beneficial. Toe: .1 degrees toe out each wheel. This amount of toe out will reduce tire scrub and understeer, and will not add to tire wear. Rear Camber to -.5 degrees. Reducing the camber to this level will reduce understeer. With a 1 inch drop or lower, you may not obtain this number without Pedders rear camber eccentrics (but I was able to get -0.6 WITHOUT these, with the Bolt Cams maxed out.) Toe to .05 degrees toe in each wheel. |
