01-24-2019, 04:43 PM | #1 |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
-2.5 to -3 camber with 20x10.5 front wheels on ZL1?
Hello,
I have a 2018 ZL1 and I'm wondering if it's possible to get -2.5 to -3 camber in the front with the addition of camber plates while having 20x10.5 front wheels (with about 7mm less positive offset to counter half of the increased wheel width) so I can fit 305/30/20 on the fronts. Has anyone tried this? The idea is to have a separate set of race wheels and use the stock GY SC G3's until I get good enough to warrant using Hoosier R7's, this summer will be my first time racing on the track, but if I buy new wheels I want to be able to use them in the future not just the short term. I saw another thread where an individual corded the outside shoulders of R7's in 2 track days on his ZL1 and then installed the ZLE DSSV's, but we are still waiting to hear back from him on if that helped.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
01-31-2019, 06:22 AM | #2 |
Drives: ISO ss 1le Join Date: May 2018
Only way to get that much stock camber is to modify your struts by grinding the little tab off, and slotting the upper camber bolt slot. (About 1.5mm will yield a few tenths of a degree). I m sitting right at -3.
01-31-2019, 10:38 AM | #3 |
Drives: 2017 1SS 1LE Join Date: Aug 2017
My car is an SS 1LE, but it's the same suspension as your ZL1.
Grind the strut ears, add camber plates up top, and you have lots of room. I'm running -3.6* camber and 19 x 11" front wheels (5th gen Z28 fitment/ZL1 1LE).
www.facebook.com/1lap1le
2017 1SS 1LE - 663 whp/623 wtq Rotofab/Whipple/Kooks 2"/LT5 TB/LT4 Fueling/E85/MCS Coilovers/Ground Control/GOODAero/Apex Wheels/Race Louvers |
02-01-2019, 09:03 AM | #4 | |
Drives: 1LEs Join Date: May 2009
I think he might be wanting to run 20x10.5 +22mm square set up that some guys use, typically, 19" with 305's. You'll need a 5mm spacer up front and grind the struts. That combo gives the same poke / location to the outer lip on the rears as a 19x12 +41mm ZL1 1LE wheel. Up front, with the 5mm spacer, it will be about the same inner clearance but poke about 12mm less than a Z28 or ZL1 1LE front (19x11 +11mm). The website below is one of many that makes for easy calculations of this... If going square, I'd recommend 19x10.5 +22mm with 305's in your choice (lots from slicks, Hoosier DOT's, RE71R's, G3R's, RS4's, etc.). You could even go 18" but strut clearance will be even less. Plus, caliper clearance will be REAL tight. https://www.willtheyfit.com/ |
02-01-2019, 09:12 AM | #5 | |
02-01-2019, 10:29 AM | #6 | |
GunMetalGrey - make sure to use Dorman, ARP, etc. of studs with more threads to ensure enough thread engagement with spacers. Some guys run 5mm spacers without changing studs. That's their choice. I would not want to go from ~14mm thread engagement to ~9mm and track it. With a 12mm spacer, you'd barely get a turn or two of the lug engaged fully without a stud change. |
02-01-2019, 10:41 AM | #7 | |
Tags |
10.5, 305/30/20, alignment, camber, wheel |
