![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1SS Join Date: Apr 2012
NOW AVAILABLE!!!!
FREE SHIPPING at Phastek Performance!!!! *Fits all 2016-2019 Camaros The Roto-Fab coolant expansion tank cover was designed to cover the factory OEM coolant tank to clean up the Camaro's engine bay. The cover is constructed out of injected molded plastic that has a factory look and feel. Installation is done by simple removing the factory over flow tube at the top of the factory tank. This will allow you to place the hose into the provision made on the Roto-Fab cover. Once the hose is feed through the hole you can reinstall the factory clamp and slide the cover in place. The optional billet coolant cap is available separately. Please install when the vehicle is at ambient temperature. Do not attempt to work on your vehicle while it is hot. Features:
ROTO-FAB COOLANT EXPANSION TANK COVER Part Number -10165028 ![]() ![]() ![]() |
#2 | |
![]() Drives: '18 2SSM6 Camaro ‘01C5Z06 Vet Join Date: May 2019
Tags |
coolant expansion tank cover, coolant tank cover, gen 6, phastek performance, roto fab |
