Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 10-19-2018, 01:19 PM   #1
fif_gen_powa
fif_gen_powa's Avatar
Drives: 2013 Camaro SS Turbo
Lightweight drag brakes
Who has swapped out the front or rear Camaro SS Brembo brakes for a lightweight drag brakes setup? How's it feel on the street cruising around town if I need to stop normally? Also what's the weight savings front or rear? I've seen Baer and Aerospacehave kits available
388ci 91/104 Turbo TH400
8.3@164
https://instagram.com/turbo_ls3/
fif_gen_powa is offline   Reply With Quote
Old 10-19-2018, 02:22 PM   #2
xc_SS/RS
Drives: 2010 Camaro SS/RS
you could also check out the brake package Carlyle Racing has: https://www.carlyleracing.com/produc...ood-brake-kit/
or their full 15" conversion:
https://www.carlyleracing.com/produc...camaro-15-kit/
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 10-19-2018, 02:23 PM   #3
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
Graf101 just did his fronts. Maybe shoot him a message
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 10-19-2018, 02:25 PM   #4
13ashengrey
13ashengrey's Avatar
Drives: 2013 2SS Ashen Grey
I've got Carlyle's out back and aerospace up front. Not really noticing any difference on the street. Aerospace says 40lbs up front. Not sure on the Carlyle rears but they are definitely lighter. I can still stop at the end of the 1/8th clocking 119 so they're still good brakes.
5.98 @ 115mph
13ashengrey is offline   Reply With Quote
Old 10-19-2018, 04:41 PM   #5
fif_gen_powa
Nice, which aerospace kit did you do drag or pro street?
8.3@164
Old 10-20-2018, 04:56 AM   #6
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
I just bought the drag aerospace front kit. they're not vented so no street use for me anymore. total kit weight is 27lbs.
for street driving the pro street kit is vented and comes in at 37lbs
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
ttshovel is offline   Reply With Quote
Old 10-20-2018, 06:42 AM   #7
13ashengrey
I got the pro street kit. Our shut down isn't very long at the track so I wanted to make sure it had the braking power to stop this tank lol
5.98 @ 115mph
Old 10-20-2018, 08:35 AM   #8
fif_gen_powa
Is that per side? Any idea what the stock stuff weighed in at?
8.3@164
Old 10-20-2018, 09:32 AM   #9
ttshovel
ttshovel's Avatar
according to them it's over 50lbs. I'll have to weigh everything and report back actual weight loss.
and that is for both sides total... pads, rotors, and calipers
Old 10-20-2018, 09:38 AM   #10
fif_gen_powa
That's really good, thanks man
8.3@164
Old 10-29-2018, 06:59 AM   #11
WEISHAAR37
WEISHAAR37's Avatar
Drives: 2010 Camaro 1SS
Stock Brembos weight
Hey fellas,
I have attached a picture of the list of exact weights of all the stock Brembos stuff. I took this off my personal car when I was swapping to V6 brakes.
I couldn't find solid weights online before I did them, so I hope this helps anyone out.
Peace,
Ben
WEISHAAR37 is offline   Reply With Quote
Old 10-29-2018, 07:45 AM   #12
fif_gen_powa
Originally Posted by WEISHAAR37 View Post
Hey fellas,
Peace,
Ben
Nice info, thank you Ben!
8.3@164
Old 12-05-2018, 10:09 AM   #13
fif_gen_powa
Just wanted to update if any one is wondering about the weight reduction of the aerospace street front brakes and carlyle 15" brakes (v6 rotor? and wilwood caliper)
aerospace front street rotor is 10.2lbs
aerospace front street caliper is 3.6lbs without pads
total 13.4lbs
carlyle rear 15" rotor is 16.2lbs
carlyle rear wilwood caliper is 3.6lbs without pads
total 19.8lbs
total saving off the front is approx 43lbs and off the rear is approx 20lbs
front rotational 30lbs less
rear rotational 13lbs less
Also weighed my weld wheels with radials before and after switching to bias ply 17 front and 15 bias ply rear
17x5 weld rts with Mickey Thompson Sportsman S/R Radial 28X6R17LT 40lbs
17x5 weld rts with M&H Front Runner Drag Tire 28.0"x4.5"-17 dot bias ply 33lbs
17x10 weld rts with m&h 325/45r17 radial 52lbs
15x10 weld rts with mickey thompson et street r bias ply 28x11.50-15 39lbs
8.3@164
Old 12-16-2018, 09:18 PM   #14
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I've had MC's rear brakes for a few years, stops just fine.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II
13.15@106 1.95 | 100% Stock
12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune
12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune
11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts
10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800
Pro Stock John is offline   Reply With Quote
