09-06-2018, 10:48 AM | #1 |
How do you change a side marker light bulb
Hi guys
Simple question I’m sure but my left front side marker light is out. Where do I go in from to change it? Do I go down from the top under the hood and remove the air filter etc. or do I go in from the front wheel well and remove the fender liner?... or something else? Thanks |
09-06-2018, 11:35 AM | #2 | |
Drives: 2018 Camaro 2SS Hyper Blue Join Date: Apr 2018
Follow this link to remove the side markers
2018 Camaro 2SS
| Hyper Blue Metallic | A8 | NPP | MRC | NAV | HUD | ATAK | |
09-06-2018, 12:04 PM | #3 | |
Bulb change
09-06-2018, 01:50 PM | #4 |
Drives: HB 2SS Join Date: Apr 2017
When I changed my entire side marker. I went in through the fender. You can unscrew it but it gets tight and for some reason none of the tools I have lined up with the head. This way is easier.
Otherwise if you don't want to unscrew anything. You can create a small hole from the side of the fender and fish a screwdriver in. Use the screwdriver to release the clips and then you can access the bulb. I would suggest of course wrapping the screwdriver in something soft so you don't scratch anything. |
