07-29-2018, 08:07 PM | #1 |
US Veteran
Drives: 2011 Silver Ice Metallic 2SS/RS A6 Join Date: Jan 2011
Front wheel wobble issue, advice please
I have a wobble in the steering wheel that I'm having trouble pinpointing how to fix. When I raise the front end and push/pull on the font/rear of the front tires there is movement in the tie rods (both sides move together). It's minimal but definitely moves and there is a clank or clunk sound (see video for sound). Everything up front has been replaced suspension-wise.
2011 SS/RS 60000 Miles. Video: https://youtu.be/bXUVwKfeBw4
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) Last edited by OmniCamaro; 07-30-2018 at 09:04 AM. |
07-30-2018, 08:08 AM | #2 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
Are you able to rotate your tires? Have you had them rebalanced?
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
07-30-2018, 09:03 AM | #3 |
US Veteran
Wheels are recently balanced yes. I actually had a bent rim for a while and just got a new one. I thought that was the problem but it’s still shaking. I do let it sit in the garage for extended periods also. I have no idea how the tires may be affected by that. But also the steering wheel feels loose while driving. I just don’t think it’s the tires.
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS) |
07-30-2018, 09:21 AM | #4 | |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
Or, do you think there could potentially be additional damage to some of the suspension components when you hit whatever to bend the rim? Like the radial arm bushings. Just spit-balling, but somethings not right if all is balanced. |
07-30-2018, 09:36 AM | #5 |
Drives: cars Join Date: May 2011
If you had an out of round wheel on for a while it likely ate one of the joints or something is very loose from the replacing. Find the clunk, pretty sure there's some slack and it will move a tad but don't remember a clunk.
07-30-2018, 11:02 PM | #6 | |
US Veteran
07-31-2018, 08:18 AM | #7 |
AKA "Beefcake"
wheel bearings?
07-31-2018, 11:10 AM | #8 |
US Veteran
08-01-2018, 05:55 AM | #9 |
AKA "Beefcake"
well dang it, I can see why we are just starring at it scratching our heads now. So if it's not ONE thing, has to be a combination of two or more things, which would really make it a very odd thing.
If it's a new wheel hub, how are you getting that much play out of it. That still makes no sense, but I am definitely not a Master of Suspension. Have you shot Justice Pete a private note asking him to chime in on this thread? He now, is a Master of Suspension and would be able to lend a new look at this. |
08-05-2019, 12:42 PM | #10 | |
US Veteran
08-05-2019, 02:56 PM | #11 |
Steering Rack?
