Old 07-14-2018, 03:54 AM   #1
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
H/C and drop-in pistons/rods
I am wondering what should I be expecting to pay for labor in NY or the tristate area for h/c and also drop-in pistons and rods. Thanks in advance
EddieM92 is offline   Reply With Quote
Old 07-15-2018, 10:09 AM   #2
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
Bump
Instagram- _2sslow_
2011 Camaro LT RS (Sold)
2011 Range Rover Sport HSE (Sold)
2016 Camaro 2SS NPP, TSP headers & Xpipe, Skid e85, CAI Intake, MSD IM, 95m TB, BigPowerRacing Tune, H&R Lowering springs, BMR sway bars
Old 07-15-2018, 10:27 AM   #3
hitmix300
2016 loaded 2SS
hitmix300's Avatar
Drives: Maverick X3 Turbo R
at any reputable shop i'd imagine 1500-2500 bucks depending on a few variables.
At my small shop in Michigan, I normally charge 600 to R & R a motor. Then about 500 plus machine shop costs for the engine build.
Obviously the shops have lot's of fee's that they need you to help pay. At smaller shops; there's a little more passion and less junk taxed.
Why don't you call a couple shops and get a quote? I would look up the dealership shop hours and do the match assuming their rate is 110 per hr.
hitmix300 is offline   Reply With Quote
Old 07-15-2018, 11:44 PM   #4
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
What would you normally charge just to do the drop-in pistons and rods? I had the question in my head as I am looking to get that done soon too. Is there a difference in cost to install JUST drop in pistons since that is the thing I know I need and the rods not so sure?
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 07-16-2018, 07:02 AM   #5
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
That's nuts. I couldn't imagine heads, cam and drop-in pistons costing only $2k to install. The lowest quote I have come across, even from large, reputable shops, was north of $4k for just the cam+parts+labor.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 07-16-2018, 07:08 AM   #6
GuywithL86
Drives: Black
That stuff is all pretty easy once the motor is out, and thats pretty easy if you’re a mechanic with a lift and do that sort of thing every day.
At $100/hour flat rate, there is no way that’s taking an experienced mechanic 20 hours. They’ll have the motor out before lunch.
20 real hours of labor they could probably take the motor out, unbolt every single physical piece of the long block, reassemble it correctly, and reinstall it in the car
It doesn’t take that long when you know what you’re doing and have the tools ready.
GuywithL86 is offline   Reply With Quote
Old 07-16-2018, 06:37 PM   #7
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
I agree with you 1000% but goodluck coming by a shop that isn’t going to charge you $6500+ for h/c and also drop in of pistons and rods. I understand these shops gotta eat also but it’s not like back in the day where shops watch out for their customers.
Old 07-18-2018, 09:44 AM   #8
62nalide
62nalide's Avatar
Drives: 2013 SS
Don't let the "drop in pistons" fool you. It is nice to just replace pistons but keep in mind you'll need new bolts might go ARP on taking stuff apart. A lot of stuff can not be reused and new to guy again. At that point you might as well do a rod and piston replacement.
62nalide is offline   Reply With Quote
Old 07-18-2018, 12:57 PM   #9
bpang1234
bpang1234's Avatar
https://gwatneyperformance.com/produ...#configuration
Like this? I will definitely buy the new ARP bolts, worth the extra expense! What about the bearings? Should those be changed if you are doing drop-in piston and rods?
I am still searching for a "ballpark" number for installation.
2016 Camaro 2ss
Old 07-18-2018, 02:29 PM   #10
DatBrotato
DatBrotato's Avatar
Drives: '18 SS 1LE M6
I was in your boat a little bit ago.
For H/C install + hand ported heads + FlexFuel tune came out to ~5k.
I tried to get a quote for drop-in pistons, shop said that'd it'd be about the same price as a full rebuild...so like 7k+ and that's without parts
cam swap on these cars is much more labor intensive/technical than on the LS motors. Most shops don't want to touch 'em.
If you're going to touch the bottom-end you're almost better off just getting a LT4 long block that comes with a warranty.
'18 1SS 1LE M6 NGM|| 11.5:1 Diamond Pistons || Callie's H-beams || Vengeance III Cam Kit || Built Heads || TSP LTs 1 7/8"(C-Coated) || MSD IM || DSX E85 || Rotofab || BMR Springs || 576/472 @7000rpm
DatBrotato is offline   Reply With Quote
Old 07-18-2018, 02:46 PM   #11
DFW1LE
DFW1LE's Avatar
Whether to replace the bearings might be a function of how many miles you have on the motor.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ
Old 07-18-2018, 06:07 PM   #12
EddieM92
Instagram- _2sslow_
EddieM92's Avatar
Yah I was looking at the GPI dropin pistons/rods/bearings kit to go along with the pray h/c kit and eventually go for FI. But for now with the h/c and pistons/rods/bearings what would your shop charge? Just to compare to what it’s like in NY
Old 07-18-2018, 06:17 PM   #13
MP3BOOSTED
MP3BOOSTED's Avatar
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C)
SO a few shops were charging me $2500+ for cam install, i ended up doing it myself, that is no where near the amount of work for drop in pistons and what not. I plan on doing that and a forged crank so yeah not looking forward to a price on that, looks like i might need to bring out the wrench and start taking the car apart again, just make sure you do it all at once, don't be like me, not smart to pay for gaskets over and over again, cometic head gaskets AREN'T CHEAP!
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw
MP3BOOSTED is offline   Reply With Quote
Old 07-18-2018, 07:17 PM   #14
aai
aai's Avatar
Drives: '17 SS/1LE/PDR
OP, drop a dime on this guy. Maybe get some work done and buy parts from him. GL
https://www.camaro6.com/forums/showthread.php?t=521521
PRAY ported MSD/TB : ROTOFAB/dry : DSX flex fuel : HPA Stage 3 : ARH catted long system/oem NPP : RSR harness bar : RSD : FSO1 : MPS4S 305F/325R
aai is offline   Reply With Quote
