07-14-2018, 12:24 AM | #1 |
Drives: 2016 Camaro 2lt Join Date: Jun 2018
2016 2lt bogged down
I was in my 2016 camaro 2lt 6spd I had a great launch (traction control on), shifted into second, then when I shifted into 3rd gear my car bogged almost like the car cut the fuel supply. I shifted into 3rd at about 6500-6800 rpm. I was wondering if this is supposed to happen for some reason?? Maybe to protect the car? Now there are some variables that may haves caused it I had a full car wich sounds stupid, but there was 4 of us in there. My car was also very low on fuel the light hadn’t come on yet but I was near to empty. Could just the combination of all those haves caused this? If anyone out there has any insight on this I would love to hear from you! Again I know it was stupid to be doing pulls with a full car but my buddies were with me and we were all just screwing around. I also realize that it very well could just be because of the conditions it was under. But if there is a system that protects the car from whatever that I don’t know about I would appreciate it! Thank you!
07-14-2018, 12:36 AM | #2 |
Drives: 2019 2LT 2.0T M6 Riverside Blue Join Date: Jan 2018
bogging in the M6 is a known issue, search the forums and you'll find multiple threads about it. I want to say it usually happens to people when they try to dump the clutch at pretty high RPMs so I suspect it is some kind of engine protection algorithm built into the ECU. But I'm not sure, I have an 18 ss 1le and its never happened to me.
07-14-2018, 04:33 AM | #3 |
Thank you Al Oppenheiser!
Sounds like a late shift to me. Easy enough to repeat a test yourself.
Street racing and the discussion thereof is a no-no on these forums. |
07-14-2018, 08:57 AM | #4 |
Drives: 2016 SS Join Date: Mar 2016
I see no reason why the engine should have bogged with a 6500 + rpm shift! My thought is that perhaps it was momentarily fuel starved due to the near empty tank or you got into the rev limiter. How long did the bogging last? I have a 17 LT M6 with about 15000 miles on it and I’ve never once experience any high rpm bog.
07-14-2018, 11:10 AM | #5 |
07-14-2018, 11:13 AM | #6 | |
07-14-2018, 11:16 AM | #7 | |
07-17-2018, 02:04 PM | #8 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
Happens all the time if you shift late. You can't really red line this car, shoot more for a 5k shift point.
