07-09-2018, 12:11 PM | #1 |
Drives: 2016 Procharged M6 Camaro 2SS Join Date: Apr 2018
1st Time: M6 Procharged Drag Strip
I went to the track for the first time ever. Quite a rush.
2016 m6 Procharged 2SS (P-1X, canned tune) Stock tires w/13,000 miles on them. 1st Run: I avoided the water box and did a quick burnout. Tried using Launch Control, and just ended up spinning. Video: https://youtu.be/67T6KJFw6Vw Time Slip: 2nd Run: Went through the water box this time and tired a little longer burnout (.5 sec?) Launched at 2000ish RPM, still was nervous and had no clue as to what I was doing. At least it seemed to hook quite a bit better. Used no lift shift which chirped the tires at each shift. Video: https://youtu.be/kStxwfFqD0Y Time slip: All in all, I had great fun and still hoping to get that number ET a bit lower. I plan to get some sort of drag specific wheels/tires (rears) but not 100% sure on the direction I want to go. |
07-09-2018, 01:44 PM | #2 |
Drives: 2016 CAMARO 2SS Join Date: Apr 2017
Damn good job for your first time
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248 PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664 GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next... |
07-09-2018, 02:00 PM | #3 |
BAMF SS
You have a 10 second car in hiding there... keep at it
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
07-09-2018, 06:45 PM | #4 |
First time ever on a dragstrip? Not too shabby.
07-09-2018, 06:57 PM | #5 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
M6s are tough to launch even with tires and less power. You did great!
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
07-09-2018, 10:13 PM | #6 |
Drives: 2017 Camaro 2SS Nightfall Gray vert Join Date: Jan 2018
Great job! What rwhp are you running?
Magnuson Heartbeat SC - Tuned by JRE Racing 776whp/745wtq (12psi) 2018 Corvette Z06 vert- Black To be tuned by JRE Racing TBD performance |
07-10-2018, 10:45 AM | #7 |
Made a pretty good improvement over your first run. Your gonna need slicks for sure to get even to mid 11's. good luck
07-10-2018, 12:41 PM | #8 |
Drives: 2010 Camaro Join Date: Nov 2009
07-10-2018, 05:00 PM | #9 | |
Thanks all for the support. I believe tires will be next, just a little hesitant on which direction on what to get. Either way I just want to get out there and enjoy it.
Thanks, don't know what it is pushing. I plan on putting it on a dyno after I get a proper tune. Quote:
I definitely would need practice to get respectable numbers. Takes me needing a procharger just to run with a Stock SS A8. |
07-10-2018, 09:16 PM | #10 | |
07-10-2018, 11:56 PM | #11 | |
Right now I'm debating on a a drag wheel/tire setup or a tune from Jannetty. The cost looks to be similar. I think that the tire route would give me better times at the strip, but Jannetty/Ted would provide more smiles daily... (1st World Problems). Either way, I might as well toss it on a dyno for fun, even though I don't have a reference point. |
07-11-2018, 07:32 AM | #12 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
With a set of axles and a pair of slicks, you should manage low 11’s without issue. Mine went 11.23@126 with the P1SC, slicks and axles. Needed the axles due to destroying the stock set.
There’s definitely enough power to go 10’s if we can ever get it to the ground.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
07-11-2018, 05:18 PM | #13 |
OP great start! Low 1.9s 60's are possible on the stock runflats with seat time. So I would say 11.5s or better should be possible with that mph on stock tires. Unfortunately the M6 has a builtin bog as confirmed by Chevy. No solutions yet as far as I know. The pros at Atco told me as my car was leaving they noticed a hesitation and wondered where I learned to drive a manual. LOL
07-16-2018, 06:35 AM | #14 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Awesome. Thanks for posting
Maybe hold off on tune until you do more mods like exhaust, pulley, fuel, etc
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
