07-09-2018, 09:39 AM | #1 |
Drives: 2014 Camaro 2LS Join Date: Nov 2015
Key ignition issue ?
My key gets stuck when I try turning off my car to get out completely. So I have to mess around for a good minute or two just to try and get the key out. Just started a couple of weeks ago and don’t know why. Anyone else have this issue ?
2014 Camaro BLK 2LS, MRT 2 exhaust,CAI,Anzo projector headlights,Morimoto HID,Aftermarket fog lights,RS tail lights, Strut tower brace.
07-09-2018, 09:54 AM | #2 |
Drives: 2014 2SS/RS Join Date: May 2015
I have had this happen 2 times now on my 14 as well. I turn it back on start the engine and, put in drive then back to park and off to get it out. seems to be a park safty issue.
It only seems to happen in my garage from some reason |
07-09-2018, 10:04 AM | #3 |
Drives: 2015 Camaro SS/2SS CRT Join Date: Aug 2015
I've had the same problem. Most of the time the steering wheel doesn't lock either. When it locks, the keys come out.
07-09-2018, 10:12 AM | #4 |
Drives: 1991 Z/28 Convertible Join Date: Feb 2018
Are your teeth worn on the key? Had a Buick Regal that did the same thing. Ended up replacing the Cylinder and two new keys.
07-09-2018, 10:30 AM | #5 |
had this on my 2015,its a known issue.dealer replaced the shifter under warranty,but others have fixed this by disabling a pin in the steering column.there are several threads on this issue.
07-09-2018, 10:32 AM | #6 |
That’s what the key looks like now
07-09-2018, 10:42 AM | #7 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
There is a long post on this topic:
https://www.camaro5.com/forums/showthread.php?t=401624 Mine did this and the shifter was replaced under warranty in my case. |
07-09-2018, 11:00 AM | #8 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
if you have happened to do any shifter "maintenance" that might also be the cause. I mean, hypothetically speaking, of course
07-09-2018, 11:16 AM | #9 |
I’ve never messed with the shifter.
07-09-2018, 12:04 PM | #10 |
Drives: 2015 Z/22 Join Date: Aug 2015
Press the shifter button a few times and you'll hear the solenoid disengage in the steering column, allowing you to pull out the key. As mentioned, some have had the shifter replaced which appeared to fix the issue.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
07-09-2018, 12:58 PM | #11 |
Drives: 2014 Camaro SS Join Date: Apr 2018
Yes this happens to my 2014 quite often, I figured out if I depress the shifter button and push forward on it it releases the key then. So I assume they have not made this a recall issue ?
07-13-2018, 08:07 PM | #12 |
Drives: Camaro SS Join Date: Jan 2015
I had the issue on my camaro and fixed it at the dealer a couple years ago. Now the problem has resurfaced again. If i want to fix it I would have to replace the shifter assembly again.
07-13-2018, 08:14 PM | #13 |
Drives: 2014 2SS blue Join Date: Jun 2016
It's the microswitch on the shifter assembly that doesn't trip the solenoid in the column. Either a new microswitch or adjusting the existing one should do the trick.
07-14-2018, 01:17 AM | #14 |
Wonder how much it would cost to have Chevy fix it ?
