Old 06-14-2018, 09:27 AM   #1
camarograna2
Car Enthusiast
camarograna2's Avatar
Drives: 2010 Rally Yellow Camaro 2SS A/T
Send a message via MSN to camarograna2
L99 Replacing thermostat
Anyone have instructions, links or video on how to replace the thermostat on a L99? Also having hard time finding the torque for the thermostat housing bolts
2010 Rally Yellow 2SS/RS
Performance Upgrades: Custom Flowmaster X system Exhaust Audio Upgrades: Too much to write down. Visit http://www.camaro5.com/forums/showthread.php?t=206016
camarograna2 is offline   Reply With Quote
Old 06-14-2018, 09:33 AM   #2
saluki
Drives: 2017 Silverado
I can't help you with the torque for the bolts.
1. drain the coolant at radiator bottom drivers side has a valve. when done close valve.
2. unbolt thermostat housing.
3.swap thermostat
4. bolt housing back to water pump
5. fill with coolant and burp it. probably the longest step. really nice to have a large funnel for this step.
Did I miss anything?
'14 2SS A6, CAI, 2" TSP Headers and tune: SOLD
'13 SS @ Burkhart Chassis
saluki is offline   Reply With Quote
Old 06-14-2018, 10:03 AM   #3
camarograna2
Car Enthusiast
3.swap thermostat
Is it absolutely necessary to have to drain it? From the youtube videos i have found doesnt look like they drained it.
Old 06-14-2018, 01:38 PM   #4
saluki
no but you will still lose enough coolant that you will still need to fill it.
Old 06-14-2018, 03:27 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Torque is 11 ft/lbs or 132 inch pounds
Old 06-14-2018, 04:01 PM   #6
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
Can I ask why you’re changing it? They are pretty resilient. Do you have mods that are causing a heating issue while driving?
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 06-14-2018, 10:07 PM   #7
xc_SS/RS
Drives: 2010 Camaro SS/RS
fill the engine from the top hose! do no fill the radiator first because if you do you will spend a few days getting air bubbles out of the cooling system
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 06-14-2018, 10:43 PM   #8
Kylejames83
Kylejames83's Avatar
Drives: 2011 camaro 2SS
I still cant get my bubbles out
Kylejames83 is offline   Reply With Quote
Old 06-15-2018, 06:26 AM   #9
chuckie669
chuckie669's Avatar
Drives: 2011 ss
Get a radiator funnel. I picked mine up after hanging out with my mechanic buddy years back.
No regrets
chuckie669 is offline   Reply With Quote
Old 06-15-2018, 07:52 AM   #10
camarograna2
Car Enthusiast
-Don
Vehicle seems to be overheating the first 15 minutes. Fans are on so thinking its the thermostat.
Old 06-15-2018, 08:13 AM   #11
WoodBoss
"Old School"
Drives: 2010 2SS L99
See this L99 thermostat replacement video below. Or you can find it from the link in my signature also. To help get the air out, fill the coolant from the top hoses and squeeze the bottom hose with the cap off to move trapped air out.
WoodBoss is offline   Reply With Quote
