06-12-2018, 06:34 AM | #1 |
Drives: 2015 1LE Join Date: Oct 2015
Best Low Dust/Noise Brake Pads
Best Low Dust/Noise Brake Pads? I have an 1LE with Brembos and looking to cut down on the ridiculous brake dust and occasional squeal of the stock pads.
06-12-2018, 07:13 AM | #2 |
'Maro
Drives: 2015 SS 6.2L Auto 2SS Join Date: Sep 2016
You will give up performance
2015 SS 2SS Auto 93 SCT Perf, Kooks LTH & HFC MBRP Axleback Muffler Delete "Z/28" Spoiler and Grille OEM ZL1 wheels 285/305/35R20 BFG G-force Pro Comp 2
06-12-2018, 07:35 AM | #3 |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
May be another reason you have squeal. I've run OEM pads on the street and track, and have never had squeal. Also, as mentioned, if you go with lower dusting, you'll most likely be giving up on performance. Pads can't perform as well if they don't break down somewhat.
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
06-12-2018, 07:40 AM | #4 |
I am not concerned about the performance.
06-12-2018, 06:42 PM | #5 |
Drives: 2011 RS Join Date: Apr 2011
AKEBONO pads=ZERO Dust. lil'squeaky when you first put them on. The car stops just fine....
06-13-2018, 06:19 AM | #6 |
AKA "Beefcake"
Drives: 2023 ZL1 Sharkskin Join Date: Oct 2009
you say that until some stupid driver, not paying attention pulls out in front of you, while your are doing 60 mph. This heavy pig needs some pads to stop it!
I have always had Hawk Ceramic pads and it really cut the dust from the OEM pads and never had issues with noise. |
06-13-2018, 06:53 AM | #7 |
PowerStop Z26. Have them on my C7 corvette and they perform every bit as good as stock Brembos, if not better....just ordered a set for my Canaro too. They don't cost much, and eliminate 95% of the dust. Don't listen to the naysayers, it'll be one of the best purchases you ever make for your car.
06-13-2018, 06:41 PM | #8 | |
06-13-2018, 09:35 PM | #9 |
You'll love em.
06-14-2018, 05:50 PM | #10 |
EbonyCamaro
What Joey said.
06-14-2018, 07:53 PM | #11 | |
06-14-2018, 08:49 PM | #12 |
06-15-2018, 01:42 PM | #13 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
i run stoptech street pads and there is less dust that stock. i start to notice the dirty wheels around 2-3 weeks after a wash or so
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
