Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 02-14-2018, 12:44 PM   #1
C-redfly
C-redfly's Avatar
Drives: 2013 VR vert ZL1
Supercharger rattle issue and a dealer said its not loud enough to fix
My 13 ZL1 has developed a rattle that I hear from inside the cabin. I took it to the local felix Chevrolet dealership and the tech said there is a noise, and that they compared it to another Z they had in and that one doesn't make the noise like mine does. But they won't change it out because they can't hear the noise above 1200 rpms. That makes no sense to me. If it's making a louder noise then another Z and if its under warranty then change it out.
C-redfly is offline   Reply With Quote
Old 02-14-2018, 01:00 PM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Rattle from the top of the engine/blower? That's the isolator. If the dealer won't touch it, the performance shop you're taking the car to for mods can replace it with a stronger aftermarket solid isolator.
Old 02-14-2018, 01:01 PM   #3
jsd
jsd's Avatar
Drives: 2012 ZL 1 #370
I would say: go to an other dealership and let do it for you. You have the warranty for your car.
jsd is offline   Reply With Quote
Old 02-14-2018, 01:02 PM   #4
C-redfly
C-redfly's Avatar
I purchased a LPE isolator a few weeks ago when I first heard the rattle but I read the shaft can be damaged from the faulty isolator, that's why I wanted GM to just change out the supercharger completely.
Old 02-14-2018, 01:03 PM   #5
C-redfly
C-redfly's Avatar
Year I talked another dealership in a nicer area where ZL1's are probably more frequent.
Old 02-14-2018, 01:06 PM   #6
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
I would go to another dealer as well. I would first videotape the sound and the refusal to replace from dealership #1. Tell dealership #1 you're going directly to GM with the complaint...and let them sweat.
JB'sZL1 is offline   Reply With Quote
Old 02-14-2018, 02:58 PM   #7
HDRDTD
Part of the original TSB for replacing the SC stated that if the rattle goes away above a certain rpm (1500 I think), then it does not qualify for a replacement.
Old 02-14-2018, 03:21 PM   #8
spadz93
BUMBL Z
spadz93's Avatar
Drives: 2015 ZL1
Go to another dealership and get the thing replaced..... and then replace the isolator and slap a pulley on that one lol
Sold: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower, Custom Camshaft, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, 680rw 93/750rw E85, Tuned by CSP
Sold: 2010 2SS, some bolt ons, 415rwhp/400rwtq
spadz93 is offline   Reply With Quote
Old 02-14-2018, 04:24 PM   #9
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I was going to say that, search for the exact guidance on when the noise fits their replacement decision.
Something about heard within the cabin with hood doors closed etc I think it says. And rpms as mentioned.
It wouldn't hurt to review that info to know and show them why it fails. Also if there are mods you can be put on the permanent no-more-warranty computer list. If you present your car to them with mods know what your doing and the consequences.
silversleeper is offline   Reply With Quote
Old 02-14-2018, 11:07 PM   #10
ZO6 Bryan
ZO6 Bryan's Avatar
Drives: 02 Z06, 95 Trans Am, 2012 ZL1
The old TSB is out of date. The info they are going by is wrong. They need to read the newer TSB. If it rattles, replace it. Doesn't matter what RPM. I'm sure someone here can come up with the current TSB. It's warranted 10 yrs or 120,000 miles
Bryan 2018 ZL1 M6
ZO6 Bryan is offline   Reply With Quote
Old 02-15-2018, 05:33 AM   #11
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
supercharger
i had mine replaced by the dealer with no bs. sounds like a bad dealership or a dickhead service manager.
rmcbee is offline   Reply With Quote
Old 02-15-2018, 06:27 AM   #12
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
This.
As others have stated... Find another dealer.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
