Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Best Rotors for the SS Stock Brake Setup?
As the title requests. I am looking for the best rotors for the stock brake offering from GM. I plan to do mostly street driving and drag racing and when I am ready to road course I will be looking at an entirely different system.
Any suggestion on new rotors? I just haven't seen many people chat about how they have liked any of the aftermarket setups yet, and I don't want to buy 5 different sets at this time to see which ones I might like.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Camaro 50th anniversary edition Join Date: May 2017
For me Brembo is on first place.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
The OEM's are going to be the best quality.
![]() Drives: 2018 Camaro ZL1 Join Date: Jul 2016
I was looking at these Matt, but I haven't pulled the trigger...
They are down there in your backyard in So Cal!! If you go check them out, let us know what you think?? https://www.r1concepts.com/ |
![]() Drives: 2016 1SS Join Date: May 2016
Im not too happy with OEM rotors, I will be looking at raybestos or centric stuff for this season (I have uneven heating issues while tracking). Also, I'd avoid anything drilled. Notice most real race cars dont have drilled rotors (not counting carbon ceramic, there are material properties things going on here I don't understand).
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
OEM, which I think are Brembo (don't quote me), Centric/Stop Tech and DBA are all fine and affordable. I've used Centric on a variety of cars in autocross, track day/HPDE and Lemons endurance racing without issue. |
#7 | ||
Lethal Camaro
My stock Brembo rotors have heated and warped a few times. once I had them resurfaced, but now I just want them gone. I am sure my can can really use a bigger brake set, but I am holding off for now.
#8 | |
#9 | |
Lethal Camaro
#10 |
Maybe start with stainless steel brake lines first. It gives you a better feeling.
Soleil
#11 |
Silly question, but do you have the brake air guides installed? Just asking because a few trips down the quartermile should be ok for the stock rotors with a few minutes in the pit lanes between your runs?
It's been fun, done with GM.
2018 Camaro ZL1 (SOLD) - Blown Airbags 2017 Camaro SS F1FTY Member Journal (SOLD) - Bad Motor |
#12 | |
Lethal Camaro
Yup, overall just looking for more bit over the stock rotors.
#13 | |
StopTech slotted have worked for me in the past once the OEM rotors wore out, along with their Street Performance/Sport pad for DD/Autox. Have you considered a different brake pad compound? You had written about going to the Z26 awhile back, not sure if you've changed those. Usually a low dust pad won't be able to brake as well when you really clamp down, but the Z26's could be different.
#14 | |
If you want more bite get a more aggressive pad, but be prepared to deal with the dust. For anything other than road course work the OEM rotors are fine, and I think theyre still okay for road course if your not an advanced driver yet, and don't require more than something like a carbotech XP10/12 or equivalent. just my $0.02 Also, did you actually notice a difference in feeling from the SS lines? I was under the impression that the new camaros and vettes dont really benefit from these anymore, as a pretty sturdy line were already used. |
