![]() Drives: 2013 VR ZL1, M6 Join Date: Nov 2017
Aeroforce & Aeroforce Vent Gauge Pod Installed
Hey guys, I recently installed a (new to me) Aeroforce Interceptor & Vent Gauge Pod in my ZL1. I won it in an auction on E-bay for $210 shipped. Couldn't pass that deal up. I'm no stranger to the Aeroforce Interceptor either... I had one installed in my Cobalt SS back in the day, and loved it. I really like how this gauge pod simply snapped in, and required no cutting or modification to fit. I had everything installed in about a half hour. Today after work, I'm finally going to get a chance to take my car for a little ride, and I can't wait to log some parameters.
![]() Drives: 2012 ZL 1 #370 Join Date: Dec 2010
Looks cool. Question, what you can show on them? Sc pressure?
![]() ![]() ![]() ![]() Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
Google is your friend (if you let it):
RPM MPH Intake Air Temperature (post Intercooler) Ambient Air Temperature (pre Intercooler) Engine Coolant Temperature Exhaust Gas Temperature (PCM Calculated) Transmission Temp. (auto trans) Manifold Pressure (vacuum/boost) displayed in PSI Fuel Temperature Battery Voltage Battery Temp Injector Pulse Width in msec. Injector Duty Cycle (%) Air Flow Rate into engine Long Term Fuel Trim Short Term Fuel Trim O2 Sensor Voltage Barometric Pressure Ignition Advance Base Spark PCM Spark Adjust Fuel Status (open/closed loop) Wastegate Solenoid Duty Cycle (%) Knock Retard Knock Sensor Raw Voltage Throttle Position Percentage Throttle Position Sensor Raw Volts Calculated Net Horsepower Engine Load Transmission Slip Current Transmission Gear Torque Delivered to Transmission Torque Converter lockup status Brake pressure Brake Booster Travel Steering Angle Non-driven Wheel Speed Lateral G's Yaw Fuel economy (instantaneous and average) P-ratio - pressure ratio MAP/Barometer 2 user configurable analog inputs** My question is the ease of installation and lower price make this a better choice than the dual pillar installation? |
Go fast, please.
I had the same set up in my ZL1 before I sold it. Best gauge for use in this car IMO. Just like you I had one in my Cobalt SS
![]() I have a carbon fiber ring for the gauge for sale if you're interested. |
I'll keep that in mind. Thanks!
#6 | |
#7 |
#8 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
Which reminds me...need to install the one I got from you. .... lol
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
#9 |
![]() Drives: 2013 camaro zl1 Join Date: Feb 2016
I just installed mine a few days ago, haven't had much time to play w it. It reads everything and I've set warning lights to come on if fuel pressure drops off, and shift light. So far I like it a lot.
Main reason I got it is to read ethanol percent |
#10 |
![]() Drives: 2014 ZL1 Join Date: Jul 2016
Did you buy the Wideband sensor kit also? Any issues with getting it connected to the SCT?
#11 |
I did not get the wideband sensor kit yet. I plan on it though.
#12 |
Should not have read this Thread.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416 ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly ![]() |
#13 | |
Yeah, I looked into the Autometer DashControl for the HUD as well, but I couldn't pass up the deal I scored on the Aeroforce and Aeroforce gauge pod. Both are great ways for monitoring the car though.
#14 |
![]() Drives: 2014 ZL1 Summit White Join Date: Jul 2012
I have been thinking of getting one I like it better than the pod set up, difficult to install?
