Old 12-11-2017, 01:54 PM   #1
Yenkocrew
Yenkocrew's Avatar
Cure for Understeer
The Car is a stock 2016 2SS with MRC using the 5th Gen 1LE/ZL1 20x10 & 20x11 wheels wrapped in a square 285/35/20 MPSS tires. The track for reference is Thunder Hill West a small and tight 2 mile located in California. My question is should I start upgrading to adjustable suspension or simply add some camber plates to the front and give it a good track alignment ?
Yenkocrew is offline   Reply With Quote
Old 12-11-2017, 02:09 PM   #2
mbar
Drives: 2016 1SS
I would start with a standard alignment. It helped me tremendously. About 2.2 front 1.6 rear. That being said, with 285/35/20 front you might have rubbing issues.
1SS, Black, Black Wheels, A8, MRC, NPP
mbar is offline   Reply With Quote
Old 12-11-2017, 02:18 PM   #3
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
What are your current alignment specs?
JRL1LE is offline   Reply With Quote
Old 12-11-2017, 02:52 PM   #4
Yenkocrew
Yenkocrew's Avatar
Current Specs are based on the recommended 1LE track specs from GM. However my tires seem to limit how much camber I can achieve since the adjustment rotates the spindle vs the entire strut assembly so the rub issue is something I had to fix with a 6mm spacer in the front. So options so far seem to be change the fronts to a 30 series to reduce the height and a more aggressive alignment ?
Old 12-11-2017, 03:25 PM   #5
HyperspaceTurd
HyperspaceTurd's Avatar
Drives: 17 1SS 6MT, 09 Tacoma TRD Sport
Camber plates would be where I would start on a strut car like these. I'm shooting for around -3 degrees up front, running a square 305/30/19 setup. On the stock rubber with an aggressive street alignment, my car rotates, probably a little too much under power, and I'm going to add more negative camber and toe-in to the back to settle it down if the wider tires don't help enough. The front camber really helps pull the car around tight corners though. I tend to run as much as I can without chewing the tires up too fast.
Make sure there is no toe-in up front, that will induce understeer right on turn-in.
I am no expert, but I have had to make several kinds of cars corner better. Once in a while I'm even successful! Sort of.
HyperspaceTurd is offline   Reply With Quote
Old 12-11-2017, 05:26 PM   #6
JRL1LE
JRL1LE's Avatar
Drives: 2017 SS 1LE
You should be able to dial out that understeer with alignment settings and tire pressure. I have done lots of laps at Thunderhill East and West. Send me a PM with the current alignment specs and maybe I can help.
Old 12-11-2017, 11:57 PM   #7
TrackClub
TrackClub's Avatar
A few comments:
1) 285/35/20 are VERY tall tires. Your gearing would be better with a shorter tire. Your turn in would likely also improve with a shorter sidewall.
2) since you have 1LE wheels why not run 1LE S3s which are a league above Super Sports and priced right.
3) don't know anything about non 1LE alignment capabilities but I run 2.6F and 1.6R (on 17 SS 1LE) on stock bolts and those specs are very good overall re handling and tire wear.
4) before spending $ on camber plates I'd see how much you can max out without them, perhaps with a similar "fix" to what some 1LE folks did for fatter wheels/tires: grinding. But if it the tire that's causing the issue I'd try a shorter one like an S3 hopefully for a better fit AND a great performance.
Old 12-12-2017, 07:17 AM   #8
apexit53
apexit53's Avatar
Drives: 22 1SS 1LE Summit White
more loud pedal on exit! hah jk.
I would start with a track alignment and go from there. You would be surprised what a good alignment can do for a car.
Where in the corner are you having the largest issue with understeer?
#53 F Street
2025 FS National Champion
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
https://www.youtube.com/channel/UCm-...3tiMt0KOg_2Aag
Instagram: apexit_53
apexit53 is offline   Reply With Quote
Old 12-20-2017, 07:38 PM   #9
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
How does the track alignment do on the street.
Pollock is offline   Reply With Quote
Old 12-21-2017, 08:52 AM   #10
apexit53
apexit53's Avatar
You will get some increased tire wear but it drives just fine I think. With the added camber it can follow some cracks and cambers in the road but other than that its not an issue.
#53 F Street
2026 Sponsors
autocrossdigits.com
karcepts.com
Autocrossing Videos
Old 12-21-2017, 08:05 PM   #11
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
John (JRL1LE) and I are both local and have a good amount of experience with these cars at that track. I agree with what he said, you should be able to get the car relatively balanced without major mods. I'm surprised you are experiencing this much understeer with a 285 square set up. Understanding that the factory tunes in understeer as it is safer, perhaps they did this more with the regular SS's compared to the 1LE's.
Start small, then work your way up.
1. Max out that camber, I was able to get -2.6 and -1.6 when I had my SS 1LE without modifications.
2. Dial in proper tire pressures
2a. Consider your driving style, what level would you consider yourself? It's not hard to drive yourself into understeer.
3. When these tires wear out, drop down to a 30 series tire.
4. Perhaps consider 1LE sway bars if different (Are they different??)
seanblurr is offline   Reply With Quote
Old 12-22-2017, 06:56 PM   #12
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
I have a regular SS w/ MRC. With a 35 series tire, max negative camber I could achieve on the front was -1.3. Tire rubs the spring perch with any more.
1LE sway bars (both front and rear) are different than standard SS, as well as control links (and springs).
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 12-22-2017, 11:06 PM   #13
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Exactly why you should drop down to a 30 series tire. 35 is much too tall.
Old 12-22-2017, 11:20 PM   #14
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
Man all this talk about short side walls. I prefer the feel of a larger side wall.
ninetres is offline   Reply With Quote
