10-25-2017, 10:01 AM | #1 |
Drives: 2013 2LT RS CRT Join Date: Apr 2017
Traded Paint With My Daughter
Daughter comes in this morning and says she backed into my car in the driveway. It's still dark and pouring so I go out a bit later to see and I don't know how she did it but the only damage appears to be a stripe of traded paint or black rubber left on the upper rear fender above the wheel well.
Could this be from a door handle? Is this burned clearcoat or something? I'm paint stoopid. How should I go about removing this? |
10-25-2017, 10:05 AM | #2 |
Res Ipsa Loquitur
Drives: 2013 Camaro SS Vert Supercharged Join Date: Sep 2012
Doesn't look too bad. You will probably be able to buff that out. Porter Cable, Meguiars Mirror Glaze 105/205 should do the trick. I don't see any dents so you should be good to go. Buff out the mark then wax.
"STREET LEGAL" 2013 Camaro 2SS/RS LS3 Convertible -- 2.9l Whipple Supercharger, CDC SportBar, Cordon CR-1 and MRR M017 wheels, Hex Vents, RPI ZL1 Splitter, CAI, Pfadt Tri-Y Headers, high-flow cats, ZR1 3 bar map sensor, ZL1 fuel pump, 3.875" pulley, ADM FPCM, 1LE PCV Oil Separator Kit, Elite Catch Can, APEX scoop and washer bottle relocation kit, Hotchkis lowering springs, BMR sways, BMR toe rods, BMR trailing arms, 620 rwhp, 564 rwtq, and tuned by Andrew Zurick of Complete Street Performance by way of Maryland Speed.
10-25-2017, 02:28 PM | #3 |
Drives: 1969 R/S Z28 302 m20 Endura Join Date: Sep 2009
if its not dented I'd try laquer thinner to remove the mark and if all good rewax it
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone 2015 Zl1 |
10-25-2017, 08:05 PM | #4 |
Drives: 2014 2LT RS Summit White Join Date: Apr 2017
It might come off with something as simple as Meguiar’s Cleaner Wax.
10-25-2017, 08:11 PM | #5 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
Looks like it should buff out....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
10-25-2017, 08:28 PM | #6 |
Tri-County Camaro SWFL
Probably can be rubbed off with a MF towel and detail spray.
10-26-2017, 07:52 AM | #7 |
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ Join Date: Dec 2010
Try polishing compound or an abrasive polish. You will probably get the mark out, but more than likely you may have sustained some creasing (dent). See how bad the spot is after you have cleaned it.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic '15 Malibu LTZ 2LZ Turbo '14 CAMARO ZL1 Blue Ray Metallic |
10-26-2017, 07:55 AM | #8 |
Drives: Love the one you're with Join Date: Sep 2009
Get her out there and have her wax on wax off til she learns her lesson. Lol
10-26-2017, 10:30 PM | #9 | |
Thanks for the advice folks! THe whole car is covered with swirl marks and wash marks from when I bought it so I've been reading up on buffing and polishing such things already. I'll try the less intensive suggestions first but I think a Porter Cable DA and cutting pads are in order anyhow for all the swirls I have. This may have just been the impetus I needed |
10-29-2017, 06:38 AM | #10 |
Drives: 2012 1LT Join Date: Nov 2015
Right here:
http://adamspolishes.com/shop/kits/4...-15mm-kit.html or Here: http://adamspolishes.com/shop/kits/4...anced-kit.html Use coupon code Oct17, he's running a 15% off sale right now, and you'd qualify for free shipping as well!
10-29-2017, 10:53 AM | #11 | |
The PC has a lot of vibration, when you use it for several hours, it will numb your hands/arms. The Rupes is the best polisher, but it is expensive. Look into the Griots Garage 6" R/0. It has a lifetime warranty. Megs D300 compound, and Megs DMC cutting pads will remove swirls easily, without all the dusting you get from other compounds. For finishing, Carpro Essence works great as it removes/fills light defects, and also provides a layer of protection that lasts up to a year. It also takes less time versus a traditional finishing polish.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
