10-07-2017, 12:02 PM | #1 |
FASTER!
Drives: Challenger Hellcat, 2SS Camaro Join Date: Apr 2008
Detailing 101
Did a quick video on some tips I've picked up over the years on detailing my rides. I like to drive more than clean, so any shortcuts I'm jumping on them.
Foam gun is the new toy and it's great. Next up is Opti Seal. |
10-11-2017, 11:07 PM | #2 |
Nice video. I like the wash board and foam gun idea. Looking forward to the clay bar.
10-12-2017, 06:46 AM | #3 |
Pat
Drives: 2017 Camaro 1LT I4 Turbo A8 Join Date: Nov 2016
Nice video! Simple and effective.
Follow me on Instagram @whiskeyfed
Subscribe on YouTube Whiskeyfed Camaro Follow my Build Thread The WhiskeyFed Camaro Current Modifications: JacFab Boost-O-Lator, Injen Evolution CAI, ZZP Catless Downpipe, RPM 3" Charge Pipe, Mishimoto Oil Filtration/Coolant Systems, R1 Concepts Brakes Package, Eibach Pro-Kit Lowering Springs, PTP Lava Exhaust Wrap & Turbo Blanket DYNO SHEET: 297whp / 374wtq Tuned by #danytechtuning |
10-12-2017, 07:44 AM | #4 |
Good video! I prefer the foam canon attached to pressure washer. I use only 2-3 oz of soap per car for canon and another 2oz in wash bucket. For soap I've used Adams Soap, Dawn, Carpro Reset, or Chemical Guys Honeydew Snowfoam and all work well in a foam canon.
10-12-2017, 10:22 AM | #5 |
Pat
Burly, how did you like reset? I have CQuartz and have heard it works wonders in conjunction with the coating.
10-12-2017, 10:37 AM | #6 | |
Retired from Car mfrs....
get more of a regular pop with ech20 rinseless.... |
10-12-2017, 11:04 AM | #7 |
Pat
I love my ech20. I used it once as a waterless and ended up with a few swirl marks. My own fault but it truly makes the paint SLICK!
10-12-2017, 12:16 PM | #8 |
Like Glen said, Reset is strong and don't use it every wash. It doesn't foam as much as other soaps but it's now my preferred soap when I'm doing a full 2 bucket wash.
Echo2 is now my go to rinseless wash. After lots of trying of different dilutions, I've settled on using 3oz of Echo2 in about 4 gallons of water. |
10-12-2017, 12:37 PM | #9 | |
FASTER!
I use Ech20 as well, and the dilution you mention above for rinseless is helpful. I was taught to also spray the panel down using a hand held pump sprayer prior to the final wipe with a clean microfiber towel. Curious what dilution you use there? The bottle has one recommendation, and their website another. Anything from 1:10 to 1:20 I believe and that's a wide range. |
10-12-2017, 01:00 PM | #10 | |
10-12-2017, 01:10 PM | #11 |
Just realize that if you’re misting/spraying the surface and misting a towel you’re doing a waterless, Not a rinseless. And long-term it’s been written up several detailing sites and my experience that you’ll get micro scratches doing this after a few years of this, Simply because you can’t get enough lubricity between the surfaces of the towel and the car, to float the towel across the car which keeps it from scratching. What does work is a true Rinseless procedure which is a sopping wet , dripping towel pulled right out of the liquid , and laid on the car, the lubricity of the ech20 keeps the towel from actually touching the surface, because the microfiber is holding so much liquid. It’s just physics.
If you want to pretreat the car with an overall spray, also don’t try and do it from a small bottle, go get yourself a garden sprayer at Lowe’s for 15 bucks, pump the crap out of it and you can spray the whole car and your trigger finger doesn’t go dead Numb, and you get more liquid on the car. |
10-12-2017, 03:24 PM | #12 | ||
FASTER!
10-12-2017, 07:23 PM | #13 | |
