10-02-2017, 05:34 PM | #1 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
Can anyone with an A8 Datalog 5th gear for me?
Hi All,
I'm having a strange issue when going WOT on my 2017 SS. Basically, when I'm and at WOT and the car shifts from 4th into 5th, I get an extended 2 seconds of time where Torque Management Advance pulls up to 10 degrees of timing. I also notice the tach does not snap back to a lower RPM like all other gears. It sorta drags down like if the converter is having trouble locking up.There is a noticeable decrease in power and then it goes away and the car starts pulling hard again. I'm going to schedule to take it to the dealer but I was hoping someone possibly had a data log on a 2016-2017 A8 car and could monitor Torque Management Advance and make a pull from 4th into 5th gear. I know its a log shot because it is a 100mph+ datalog. Thanks |
10-05-2017, 09:37 AM | #2 | |
If it fails to be corrected by the fluid change they replace the converter and rebuild the trans from what I have heard through the grapevine. Ted.
www.jannettyracing.com
10-06-2017, 01:07 AM | #3 |
Drives: 2017 Camaro 1SS A8 Join Date: Jan 2017
I have the same issues and have noticed it on many A8 videos. I have had my torque converter replaced and it's still an issue. I just chalked it up to the gearing in the car. It definitely cause the car to lose mph.
10-06-2017, 12:43 PM | #4 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
I have noticed this as well it seems like the car is under extra labor when the 4 to 5 shift is first executed. More so than any of the prior shifts almost as if the jump in gearing from 4 to 5 is alot more than any of the prior shifts.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
10-06-2017, 03:50 PM | #5 | |
Snackbar Tuning
I'm going to end up taking it in to the dealer soon just to have the converter replaced. But I still wanted to see if this TMA thing was normal or not. I assume the ECU is activating it past the shift point due to the laggy shift. |
10-07-2017, 07:31 AM | #6 |
How does one describe this to the dealer? It's gonna be hard to convince them to do a 4th to 5th wot pull. Lol
10-08-2017, 01:41 PM | #7 | |
Snackbar Tuning
I do have a great dealer though. My service advisor told me they would cover the warranty on my car if I modified it up to intake/headers/tune. I asked, but tuning the car is a big no no?? He said if the car is done right and taken care of it is not a problem. The dealer doesn't have to tell GM anything. However, he did say if I ran E85 they would not cover the engine and advised that I do not do it. Anyhow, since I had transmission issues before, my dealer said if I report any more troubles they will just replace the converter immediately. The only thing that is stopping me is that I want to see someone's datalog from 4th-5th to see if the the Torque Management Advance is behaving the same. It's either normal and more noticeable from the extra power I have, or the converter is having trouble locking up and causing the ECU to see a problem and is continuing to pull timing via TMA beyond the shift point. |
10-08-2017, 09:44 PM | #8 |
Mines been doing the same shit for months(violent shift from 4th to 5th at WOT). 3 trips to the dealer and they've done nothing. I'm at a loss on what to do.
10-09-2017, 08:33 AM | #9 |
This is the main reason why I haven't tuned the car... First time buying a new car and been in the shop more times than my 335. Lol
10-09-2017, 09:01 AM | #10 | |
Snackbar Tuning
I will say that once I had the triple flush and TCM reprogram at dealer, the random harsh shifting was gone. And I took it in for the "rumble strip" vibrations. |
10-09-2017, 09:21 AM | #11 |
I have seen the torque management pull some timing in the beginning of 5th on occasion. After the shift to 5th, timing came up from negative during the shift to about 10~15 degrees retarded briefly, then came up to normal afterward. This is not what it normally does, but has happened.
10-09-2017, 12:08 PM | #12 | |
Snackbar Tuning
10-09-2017, 12:37 PM | #13 |
Same here... swear I lose races because of it lol. I noticed a 2-3mph drop when it used to happen randomly.
10-09-2017, 03:54 PM | #14 |
So while I was perched on my porcelain throne a thought scampered through my
Mind.. What if Chevy implemented a major TQM program from 4th to 5th gear to ensure that the corevette will always dominate top end? |
