Old 09-14-2017, 03:51 PM   #1
NightSkyCode
Owned gen 4, 5 and 6
NightSkyCode's Avatar
Drives: 2017 Camaro 2SS
New buzz and squeak (of course)
Well, 2500 miles in I've heard and fixed many interior noises from my car. Squeaky/creaky air vents. Plastic on plastic noises, bumps causing rattles, etc.
However, I now have the most annoying new one. A buzz and what sounds like a glass window squeak noise when I hit light bumps. Sometimes on the freeway if i'm on the right road it will be buzzing in my ear the entire time. Its coming from the area in the photo. Maybe behind the seat belt? Does anyone know what can be causing a buzz/noise around this area. I don't want to go the the dealer, because 1 they make things worse, and 2 they will call me crazy when they cant reproduce it.
2017 2SS, Mosaic black <3, NPP Exhaust, MRC, GM CAI, Loaded.
NightSkyCode is offline   Reply With Quote
Old 09-14-2017, 04:36 PM   #2
camex
Drives: Sold
Maybe, plastic pieces from bottom of the door?
Mine are all loose and rattle so I taped it all.
camex is offline   Reply With Quote
Old 09-14-2017, 05:41 PM   #3
NightSkyCode
Ill give that a try and report back. Thanks!
Old 09-15-2017, 01:19 PM   #4
pjz1082
pjz1082's Avatar
Drives: 2016 Camaro 1LT
[QUOTE=NightSkyCode;9905591]Well, 2500 miles in I've heard and fixed many interior noises from my car. Squeaky/creaky air vents. Plastic on plastic noises, bumps causing rattles, etc.
I've developed a rattle in that area. It's really noticeable on bumpy roads. Pretty sure the cheap plastic clips on the side of the door are causing it. See pic below for what I'm referring too...
pjz1082 is offline   Reply With Quote
Old 09-18-2017, 06:22 PM   #5
NightSkyCode
That actually looks about right. Any fix?
Old 09-19-2017, 01:22 AM   #6
Sheriff37
Do it for Dale
Sheriff37's Avatar
Drives: '16 NFGray V6 M6
It could be caused by the piece coming loose from the vibration from driving. Maybe just run a piece of tape over it to see if that fixes it, if it does then later try to go a little more permanent with some glue under the piece or something .
Sheriff37 is offline   Reply With Quote
Old 09-20-2017, 05:24 PM   #7
pjz1082
pjz1082's Avatar
This. Slap some tape over the plastic clips and see if that fixes it. I would also do the same to the door plugs. As for a permanent fix, maybe some foam tape. Just like you use to attach emblems to exterior. A few small pieces should stop things from moving around.
