Old 09-09-2017, 07:16 AM   #1
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Question for those who installed bmr toe rods.
Did your kit come with with replacement bolts for both the inner and outer toe rod bolt locations. I had to reuse all 4 stock bolts as the bolts that came with the kit were way to short to use on the inner toe rods. I have attached a picture of how i have the bolt installed on the rear of the vehicle. The second picture shoe how i currently have them installed with tge exception of not having the lockout washer installed behind the nut on the right. The first picture shows the really short bolt they sent me, that isnt long enough to install on the inner bolt location like there instructions state. Third pic just onstalled picture. Hoping bmr responds as there closed on eeekend and let me know if stock bolt is adequate for install until they send longer bolt. Also that bolt you guys sent me is shorter than the outer bolt too. Didnt use it as i figured it may be wrong bolt.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 09-09-2017, 03:28 PM   #2
Paully104
Novice Driver
Paully104's Avatar
Drives: 2016 2SS Silver
It's been a minute but they had an issue where my bolts were not sent with a part , may have been my toe rod. They might have given you the wrong bolts , I would wait for their response and use your stock bolts temporarily. When I didn't have the bolts I used the stock ones for a week no problem.
Modifications: BMR suspension & front brace, DSC v2 controller, ported throttle body, Rotofab intake, Rimblades rim protection (red)
Paully104 is offline   Reply With Quote
Old 09-09-2017, 08:56 PM   #3
bybcous
bybcous's Avatar
I just want to post a positive comment, my car is putting down the power alot better. I already had there springs, trailing arms, and control arm. I installed the toe rods and rear chassis brace today and there is a huge difference. I like it alot. Cant wait to see what track times show.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 09-12-2017, 12:04 PM   #4
PolynesianPowerhouse
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
Wanna find out as well these are on the "up next" list
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 09-14-2017, 04:26 PM   #5
BMR Tech
BMR Tech's Avatar
bybcous,
I apologize for the delay in responding. We are still working without power after Hurricane Irma passed through. Please contact me tomorrow and I will get the correct hardware shipped out.
frank@bmrsuspension.com
813-986-9302 x114
BMR Tech is offline   Reply With Quote
Old 09-20-2017, 04:57 PM   #6
bybcous
bybcous's Avatar
Gpt the parts today and i didnt call, thanks. Will peobaly install them this weekend if i wont need a realignment after.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 09-21-2017, 09:21 AM   #7
BMR Tech
BMR Tech's Avatar
10-4 glad you got what you need. I would definitely recommend getting an alignment once these are installed.
Old 09-21-2017, 09:05 PM   #8
reeper
reeper's Avatar
Drives: 2010 HD D/A, 2015 Z06, 2016 2SS
Sorry late to the party. I've got pretty much all BMR's stuff including toe rods. I actually called during install with the same question. It would be tough to use their bolts due to length. They said you could use the stock bolts and torque to spec.
The difference in the handling and launching is insane - its like a different car.
2016 Hyper Blue A8 2SS
GM Bodykit: Black
MRR 017 wheels: Black
OEM Blackout tail-lamps
OEM SEMA Grille
35% window tint
Black glow-tie
BMR Suspension (Pretty much everything)
ACS rear-deck spoiler
Rotofab CAI
Lolly-pop red rotors by Madison Powder Coating
reeper is offline   Reply With Quote
Old 09-22-2017, 11:17 AM   #9
BMR Tech
BMR Tech's Avatar
If you are still using the stock bolts, contact me with your info and I will send you the correct hardware.
Old 10-19-2017, 06:43 PM   #10
bybcous
bybcous's Avatar
Bmr you guys sent the bolts awhile ago but without the nuts, i plan on changing bolts this weekend, should i reuse the stock nuts? Also will i need to get anpther alignment if i an just changing the bolts out and torquing back down to your recommended spec?
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 10-20-2017, 09:07 AM   #11
BMR Tech
BMR Tech's Avatar
Yes, reuse the original nuts on the new bolts, we do not provide new nuts in the kit. As long as you change the bolt out and do not adjust the length of the toe rod your alignment will not change.
Best Regards,
