Old 09-06-2017, 08:06 AM   #1
Jamesg89
Jamesg89's Avatar
Drives: 2019 2SS & 1998 SS
Attention all M6 guys with slow start/no start when hot
Backstory....my car has been in and out of the dealer for 2 months for not wanting to restart when it gets hot/or super slow start when gets hot. Its left me stranded a couple times. They could never figure it out. It wouldn't start but had power and all.
Come to find out I have a bad thrust bearing and the engine was halfway locking up. 27k miles and my car needs a new motor.
I know other guys have had similar issues, so if your in the same boat have them check the car for crank walk. Mine is pretty bad. The only reason they figured it out was the CEL came on for a crank sensor, and it finally led them to the issue.
Not sure if this would effect the A8 guys as much as the M6 guys but its something to remember if your car is having this issue.
Jamesg89 is offline   Reply With Quote
Old 09-06-2017, 09:04 AM   #2
ZNix
Drives: 1987 Buick Grand National
Oh joy....
ZNix is offline   Reply With Quote
Old 09-06-2017, 09:42 AM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
wow...20 yrs later and GM still having some thrust bearing issues. I seen a few LS1's over the years have the same issue. I do not think it is very common though.
Old 09-06-2017, 09:53 AM   #4
Jamesg89
Jamesg89's Avatar
Yea not sure how common it is. GM definitely knows about it because the tech told me when he called the GM hotline and explained the issues, they are the ones who told him what to check. So evidently they know about this issue somewhat. I have seen a few posts of guys having similar issues, so just wanted to give a heads up if people were having the same issue as me. Dealer couldn't find the problem forever.
Old 09-06-2017, 10:13 AM   #5
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
So OP, your car refused to start when it was hot? How hot? 200-210F? Hotter? Ive had the slow start issue, but never has it not started. I believe it start slow for me when sitting at an incline.
soloknight6 is offline   Reply With Quote
Old 09-06-2017, 12:07 PM   #6
Jamesg89
Jamesg89's Avatar
Yes multiple times it would crank super slow and not start. Lots of times it cranked slow but did fire after a second. My car rarely sees 200 degrees. So anywhere around 180 or so was when it would do it.
Old 09-06-2017, 12:13 PM   #7
Marty McFlew
Drives: 17 SuperSport Camaro 6 on the Flo'
So if Chevy knows about it, is it a manufacturing issue or an issue with installing or just a design issue?>
Marty McFlew is offline   Reply With Quote
Old 09-06-2017, 12:17 PM   #8
Jamesg89
Jamesg89's Avatar
They never elaborated on the root cause of the issue. They haven't even pulled my oil pan yet. They have just diagnosed and and sent GM the picture of the software to make sure it wasn't tuned I guess.
Old 09-06-2017, 12:24 PM   #9
Marty McFlew
OK Please keep us fully updated.
Old 09-06-2017, 01:37 PM   #10
Capisce
Drives: 2016 2SS Camaro
Hmmm... The other day after driving for a little while and knowing the car was warmed up I had the perfect opportunity to let it rip. Wide open 5 lanes wide coming out of a toll booth with no cars in sight. After that I stopped at a store. When I came out it did have trouble starting back up. Cranked slow but finally did start. A8 here.. Wonder if I should be concerned too
2SS - Summit White - MRC - NPP
Capisce is offline   Reply With Quote
Old 09-06-2017, 01:47 PM   #11
Jamesg89
Jamesg89's Avatar
Normally manual cars are the ones you see crank walk issues with, but anything can happen. That's exactly how my car was, except at times it wouldn't start. I wouldn't have to rip on mine, just needed to get up to temperature. And it seemed the hotter it was outside the more it would happen.
Old 09-07-2017, 01:17 AM   #12
gippy87
Drives: 2016 2ss
mine slow starts as well. I've had a number of people comment that I need a new battery but i've always responded that it was normal because its happened since day one of owning it. Slightly annoying but hasnt left me stranded yet.
gippy87 is offline   Reply With Quote
Old 09-07-2017, 02:49 AM   #13
Oil Man
Oil Man's Avatar
Drives: 2016 2SS, 2018 ZL1 A10 (RIPx2)
This sounds like my experience as well. I have yet to experience a time where I pressed the start button and it did not ultimately kick over. I chalked it up to a combination of the starter/solenoid assembly being heat soaked, coupled with these new AGM batteries which seem like a compromise that trades cranking amps for a pretty solid weight reduction.
A thrust bearing failing so early sounds like a problem at the engine plant. Sorry OP. That sucks.
Oil Man is offline   Reply With Quote
Old 09-07-2017, 01:52 PM   #14
Jamesg89
Jamesg89's Avatar
Yea it sucks, especially since its getting time to put the car up for the year.Now the car has just been sitting outside for 2 days no work done...this dealership will hate me by the end of this. Im not gonna have one of those stories about not having my car for a month over a job that should be finished in a week. I was a tech for 7 years I know how they work.
