Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 09-06-2017, 06:20 AM   #1
1badbish
GODDESS
1badbish's Avatar
Drives: 2010 Camaro SS
6L80E Transmission Problem HELP ME!
Short Synopsis: No 1st, 2nd and Reverse gears.
So, the weirdest thing happened to me the other day. I was sitting at an intersection and when the light turned green, I hit the gas to go and the car acted like it didnt want to move. Now, the car did something funny while I was sitting at the light, it felt like i put the car into gear which i didnt because it was already in drive and i was at a stand still. Instead of driving it home, i just got it towed. There were no codes.
A little background info. 2010 A6 with 108k on the motor. There has never been any slippage or other symptoms related to the transmission that i know of. Ive had the car for 6 1/2 years. I honestly dont believe its a mechanical failure. What do you guys think?
1badbish is offline   Reply With Quote
Old 09-06-2017, 07:34 AM   #2
butch2000
butch2000's Avatar
Drives: 2010 RS , SS , supercharged ,
fluid level check for sure , or drop the pan and see if there are any signs of debris indicating some type of mechanical failure ? when my TCM failed it acted wired as well ,
butch2000 is offline   Reply With Quote
Old 09-08-2017, 04:19 PM   #3
1badbish
GODDESS
1badbish's Avatar
I can manually put it in M3 and it moves fine but when in Reverse it lunges forward before abruptly coming to a halt.
Old 09-16-2017, 11:45 AM   #4
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Best thing to do is drain the fluid. Kind of the same thing happened to mine so I swapped to a th400
camarosspower is offline   Reply With Quote
