08-20-2017, 08:56 PM | #1 |
Drives: 2017 1ss m6. Blue..... Join Date: Mar 2017
BMR toe rods squeking?
I installed bmr springs, upper and lower trailing arms, toe rods, and cradle lockout. When i drive the car and then park, i can push on the back end and it seems the ball jointed toe rods are squeking really bad. Has any one else had these squak like that, they also are tilted all the way forward or backward on the ball joint, they never stay straight up and down but i dont see that being a reasson for them to squek. Any info appreciated!
08-21-2017, 02:55 PM | #2 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
It's probably not the toe rods. It's probably the poly bushings in the trailing arms. Did you grease them? Poly bushings are known to squeak a little.
08-21-2017, 05:36 PM | #3 |
Yes i greased em3 times with mobil 1 ( trailing arms). Looked more into it and the mustang owners had it happen also on there parts with the ball jointed ends, same thing, worse after you drive. I can put my hand on it and feel the toe rods creak... im going to try lubeing em and see what happens
08-22-2017, 10:48 AM | #4 |
Drives: 2016 Camaro 2SS Join Date: Sep 2009
We have not seen this issue with the 6th Gen toe rods before. The Mustang part we had this issue with is a completely different type and even manufacturer of bearing that is used in the rod end of the TR007. I have however seen this on some of our other rod end parts when exposed to harsh driving conditions and the joint gets dried out. Is it both sides or only 1 specifically? Try removing the toe rod in question, use brake clean to rinse off any foreign debris from the ball part of the rod end, then apply a lubricant. We recommend a motor cycle chain lubricant or something similar to provide a good protective coating as well as lubrication. If the problem persists after that, contact me directly and we will replace the rod ends
08-22-2017, 01:38 PM | #5 |
This stuff works GREAT for protecting and lubricating BMR Rod Ends!!! As Eric said, clean them up good with brake cleaner first, then coat them liberally with this stuff.
08-22-2017, 03:50 PM | #6 |
Awsome, i got some chain lube from when i used to ride. It is both sides, first it was one side. Then again i figured they just needed lube, the car was driven in the rain two times so far, and probably has 800 miles on the toe rods. They perform great so far. Ill clean and lube em this weekend and post back!
08-22-2017, 03:52 PM | #7 | |
Drives: 2016 Camaro 2SS Join Date: Aug 2009
08-24-2017, 12:29 AM | #8 |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
I had squeaks from mine as well... chain lube (or this stuff) quieted it all down. I've driven it through one winter without any issues. I just cleaned/lubed the ball joints before and after the winter.
08-24-2017, 08:35 PM | #9 | |
If i remove em to clean and lune theme, do you huys think ill need a realigment ? |
08-25-2017, 12:09 AM | #10 | |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
08-25-2017, 10:47 AM | #11 | |
Depending on how much you drive, you could probably get away with lubing the parts during oil changes... that way the car is on a lift and everything is easy to reach. I agree with PolynesianPowerhouse, at least get your alignment checked if you end up taking off the link.
08-25-2017, 04:06 PM | #12 |
All good advice in here so far. Try this out and report back with your results!
08-26-2017, 03:59 PM | #13 |
I had the car realigned when i installed all of my parts, so ill have to try and relube them with the wheels off
08-26-2017, 05:20 PM | #14 |
Ok, i pulled the wheels off, cleaned and lubed the toe rods, just drive the car and they still squeak. I also regeased the upper and lower trailing arms. Im runnin out of ideas....
I dint know at this point if it is the toe rods, i cant seem to pinpoint the squak. I might have to take it all apart to figure out whats going on. Last edited by Hyperlinkblue; 08-26-2017 at 05:38 PM. |
