08-07-2017, 10:33 PM | #1 |
Drives: 2017 SS 6sp Join Date: Jun 2014
LT-1 failure
is the LT-1 motor more prone to failure than the LS motors? it seems that I have been read more story about the LT motor breaking bottom end pistons and such or is it people are pushing these motors harder.
08-07-2017, 10:48 PM | #2 |
Drives: 2019 ZL-1 Join Date: Feb 2009
They are complicated motors. They can handle the power, but a spun bearing can happen. There were failures in the LS-7 due to exhaust valve guides too.
2012 Yukon XL Denali w/ 6.2 AWD |
08-07-2017, 11:01 PM | #3 |
Drives: 2017 Summit White 2SS Join Date: Jan 2017
No idea about the failures, for me it just sucks that GM limited the fuel system so much. The ls3 guys can go and get 650-700 hp on a mostly stock system :(
08-08-2017, 03:17 PM | #4 |
Hmm My 625-650 rwhp LS3 needed both the ZL1 Fuel pump (which the 1LE had) and larger injectors. If I went over 700 I was told I needed a better pump to be safe.
08-09-2017, 12:11 PM | #5 |
Drives: 2010 Camaro Join Date: Nov 2009
The LT based engines are GM's best V8 to date. But, ALL GDI engines experience stresses and issues the old port injections never did. First you have the intake valve coking issues and related wear to the valve guides. Then as these hard abrasive deposits shed particles, these are forced past the rings and cause scouring to the pistons and cylinder walls as well as rapidly contaminate the engine oil. As the average oil filter can only trap down to 12-15 microns in particulate size, much of this remains in the oil circulating and wearing components. Then as the fuel is introduced directly into the combustion chamber at 2,000-3,000 PSI and the compression ratio is 11.5:1, many times the fuel is pushed past the rings to dilute the oil further increasing wear and shortening engine oil life. This is why ONLY using a full synthetic and installing a proper catchcan system is so critical with these engines if you intend to get the most life from them. Engine oil is considered "condemned" at 5% fuel dilution, and it is not unusual to find levels exceeding this by 2,500-5,000 miles on a GDI engine. So, these while amazing in engineering and performance, they need end user intervention to last unlike the past port injection engines that could go 200k plus miles with minimal care in the past. As the industry considers 50k miles the trouble free life of these engines VS 100k in the past port injection engines. (Look at your engine warranty now VS the Gen5).
So, taking the proper steps to ensure a long life will still get you plenty of use from these, they cannot just be treated as the engines of the past. |
08-09-2017, 02:28 PM | #6 |
08-09-2017, 05:29 PM | #7 | |
Drives: 17 SuperSport Camaro 6 on the Flo' Join Date: Feb 2016
08-09-2017, 07:16 PM | #8 |
They don't recommend catch cans since the car will be out of warranty before problems arise. That's our problem then. They don't put them on at the factory since it would drive up the price of the vehicle.
08-09-2017, 07:40 PM | #9 |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
And they'd be a maintenance nightmare for 99% of drivers who wouldn't give a crap to service them.
08-09-2017, 07:47 PM | #10 |
Yes exactly!
08-09-2017, 09:32 PM | #11 |
SoCal HT5! SD
Drives: 2016 red hot 2ss M6 Join Date: Nov 2011
I wonder if the LT1s that failed had the bad oil pans. Hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm...
http://www.camaro5.com/forums/showth...37#post5437037
By my deeds, I honor him. V8!!! |
08-09-2017, 09:49 PM | #12 | |
Drives: 2016 Camaro SS Join Date: Jul 2016
Catch cans... Give me a break. |
08-09-2017, 10:41 PM | #13 |
Drives: SW 1SS 1LE / Jeep XJ Join Date: Mar 2016
They need sales As oil filters go, Fram Ultra is 80% at 5 microns , 99% at 20 microns. The AC Delco filter,PF64 is listed at 98% at 25 microns and definitely filters below 12-15 microns. Also fuel dilution for DI Engines is real but not all have engines have fuel dilution problems. From the used oil analysis I've seen from the LT1, fuel dilution isn't an issue for us. And remember you can get fuel dilution in any car(port or DI) with short tripping. |
08-09-2017, 10:53 PM | #14 |
Drives: 2016 Camaro SS 2ss A8 Join Date: Jun 2016
I purchased my 2016 Camaro ss new with only 3 miles in it. Only full synthetic oil changes since day one at 4,000 mile intervals. Current miles a little over 19,000 and at the dealership with a complete motor failure. New crate motor from Gm was ordered last week and has been installed as of today. Update from dealership after test driving the car with new motor. Transmission is possibly shot as well. Still trying to get a full description of what actually failed but their not really telling me much.
