08-06-2017, 03:21 PM | #1 |
Drives: 02 Camaro SS 6M / 11 GMC Sierra Join Date: Mar 2017
check engine flashing after hard acceleration
This hasn't happened to me before I jumped on the highway and accelerated hard to redline at wot Shift gear and check engine light came on and stayed on for about a minute or so flashing then it went off. Only mod is a drop-in K&N Filter and I run 91 octane gas and synthetic oil car has just under 4,000 kilometers on it 6-speed manual
08-06-2017, 03:58 PM | #2 |
Drives: '17 Hyper Blue RS, NPP, 6MT Join Date: May 2017
Hmm that's interesting... Can it be replicated with the same method or was this just a one off so far? I haven't experienced this.
08-06-2017, 04:14 PM | #3 |
Drives: Traded in 2016 BLUE VELVET 2LT RS Join Date: Aug 2016
This has happened to me atleast twice. Once when I first got past the 1500 mile mark did a hard 0-60 run, blinked and went away. The code was P0301, I reset the code. It happened again 2 months ago on a rolling 60 to 100 pull, blinked like crazy. No code this time.
http://www.camaro6.com/forums/showth...hlight=misfire |
08-06-2017, 04:29 PM | #4 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
flashing light usually denotes a misfire... for whatever reason, it prob misfired and then cleared its way again.
this went down on my 2013, and sometimes can denote the variable valve timing piece is stuck for a sec, or worn in older cars. think of your heart trying to pump blood, but the valve doesn't open immediately or all the way. keep an eye on it. some 5th gens had timing chain skips and the vvt accounted for it, but under hard acceleration, it would show its head again.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
08-06-2017, 07:08 PM | #5 |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
Yeah that or knock sensor is catching too many hits and its cutting power.. are you noticing the car going limp at all during the CEL being on ? Either way have it checked out if you can replicate it. Try higher octane gas especially if you are running 87 I ran 87 octane 1 time and I could hear the engine knock... Never again did I run 87.
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com |
08-06-2017, 07:17 PM | #6 | |
08-06-2017, 07:18 PM | #7 | |
08-06-2017, 07:19 PM | #8 | |
08-06-2017, 07:51 PM | #9 |
Yea. My lfx had the same. Windering if its inherent of the DI engines design?
08-06-2017, 08:48 PM | #10 |
08-06-2017, 09:09 PM | #11 |
Mine is stock except for the Borla ATAK and Tint. I always run 93 Shell or Chevron. While I was down in Florida, I used Mobil.
08-07-2017, 06:40 PM | #12 |
08-09-2017, 04:51 AM | #13 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Did the same with mine. I think mine went several hundred past red line though and the check engine light came on so I backed down and after about 30 seconds the light went off. I thought we had rev limiters and that was the only time I red lined it and it was not a pleasant experience.
08-09-2017, 04:04 PM | #14 |
Drives: 2017 1LT A8 (SIM) Join Date: Jun 2017
Just curious, since octane was brought up twice, does the LGX pull timing due to knock with <91 octane? I am convinced it was pulling tons of timing on 87, and it seems super smooth on 89. I hadn't made the leap to 91 (or 93, since we have it in Florida) since 89 seemed good on the butt-dyno.
2017 1LT (A8): 30% tint - Tinted taillights - Blackened bowties - Muffler delete |
