07-10-2017, 01:19 PM | #1 |
Drives: Garnet Red - 20 ZLE Join Date: Jun 2016
PRAY Ported Heads
Brett was kind enough to let me get the first pair of PRAY PERFORMANCE ported cylinder heads. Im currently in the middle of the install right now. Both ported heads are on the car its just a matter of getting the rest of the mess back together during my busy work week.
Guys, I cant say enough about Bretts work. Not only does he do top flight porting, he has been extremely helpfull with the install and making sure I get it done correctly. Always willing to help and offer advice. I cant wait to see what this car car do in its final form. The install is not easy if you have never done it before, I wont sugar coat it. Anyway, results to come after I get it back together and retune it. I will leave you with a few pictures, although poor quality. Sorry. |
07-10-2017, 02:11 PM | #3 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Oooooh really nice! I look forward to reading your impressions for how they feel. Any before/after dyno's by chance?
Are you keeping the stock cam, valves, and springs? Just the porting change? Thanks! Ryan
07-10-2017, 02:36 PM | #4 | |
I want to maintain stock drivability but make more power and this was about the last thing I could do outside of cam the car. I'm really excited to see how it feels. I can tell you that having both heads laying side by side you can see all the areas that Brett worked over, they are SMOOTH compared to the very rough and pourous nature of the stock ones. |
07-10-2017, 02:39 PM | #5 |
SABIO
nice...
So that what Heads look like....
07-10-2017, 03:16 PM | #6 |
07-10-2017, 06:09 PM | #7 |
SABIO
No,no...
Was not a comment on your photography skills. But I can see why you thought so. It is kinda funny though...
07-10-2017, 06:50 PM | #8 |
Drives: 2016 2SS Join Date: Jul 2016
Just to clarify. Bradford is NOT waiting for heads from me.
07-10-2017, 06:54 PM | #9 |
Nick, glad you are happy so far. It is great that you got the first set. Can't wait for your impressions once you are up and running. I am confident you will be happier than you are now. I appreciate the nice words. You have been an exceptional customer to deal with. Providing help is the easy part. Just glad I could be part of your build.
07-10-2017, 07:24 PM | #10 |
SABIO
Sorry...
Didn't mean to mess up this thread. I'll go now Yes. Pray Performance. Solid parts. Great guy.
07-10-2017, 07:58 PM | #11 |
No worries brother. I just didn't want people think I was the source of your current issues. I really wish you were able to make it to the Fest.
07-11-2017, 12:17 AM | #12 |
Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
Good luck man. Enjoy.
I plan on a set down the road when I do a cam. PRAY is the man. Still torn between a big cam and converter deep into the tens or a mild cam stock converter consistent mid to high tens... I feel like a mild cam with some milling and thinner gaskets could get decently close to a large cam and sacrifice very little drive ability I also dabble in roll racing from time to time and the stock converter may be better for this... What kind/size of cam do you suggest with these heads pray? |
07-11-2017, 05:18 AM | #13 | |
A converter won't hurt your roll racing. Once you click over to manual mode you are all locked up. It is just like putting it on the dyno. You can also adjust your converter lock up mph to cover down on roll racing speeds. Any cam above 223 intake duration will usually require enough idle rpm that it will pull on a stock converter. I am not sure how the A8 stock converter fares with this but that is about the limit for all the GM converters before it. My heads flow enough air and high enough into the lift range to handle any cam you want to throw at them. However, I am not sure on cam specs yet. It appears that there is not nearly as much PTV as I was originally lead to believe in this motor. This severely limits how far forward we can advance the IVO/IVC. The IVC directly effects the DCR we can get and therefore effects the tq we will be able to produce and where in the rpm band we can make it. Given the flow characteristics of my heads I have had the best luck running cams with a tight lobe separation 110-111 and a 6*-8* split on duration. Advance is now the issue. I would say that running a bit of advance and using the computer to retard the cam would be best. But again there is the PTV issue. We are also finding out now that there are cam retard control issues with valve spring pressure overcoming the cam phaser. I have seen this first hand on the dyno with unexplained tq dips in the curve. Once we logged cam retard we found out that cam was not following the commanded retard at all. It was retarding the cam up to 5* in certain spots for no reason. Some manufactures are now offering 0*-4* limiter blocks now vs. the 25* block that comes with the comp phaser limiter kit. We are assuming that the oil pressure and spring in the stock cam phaser can't overcome the spring pressure required to run the cams being produced right now. I still can't wrap my head around the wide lobe sep we are seeing with most of the cam manufactures right now but no one seems to want to have a conversation about it. It seems like a double whammy to me for tq production down low. I feel it would be much better to run a tighter lobe sep with no advance than run a wide lobe sep and some advance.. There must be a definitive IVO that will maintain the minimum PTV. The other issue is ramp rate. By degreeing different cam manufactures cams there is a definite difference in ramp rates. It is the .020"-.050' that seems to be the issue for PTV with some cams and not others. So duration and IVO aren't the only issues to plan around. I will figure it out eventually with a buddy of mine and then come out with my own line of cams to match my head porting.
07-11-2017, 09:42 AM | #14 | |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
