06-10-2017, 09:54 AM | #1 |
Drives: a car Join Date: Nov 2016
06-10-2017, 10:31 AM | #2 |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
Phastek lines won't work on the 6-piston calipers.
Use a shop you trust, or the dealer (I guess..?) I love the way the brakes feel, especially with good fluid and steel-braided lines... but you won't get any actual stopping benefits outside of track use, or stopping from extremely high speeds. Don't get caliper covers... just get your rear calipers painted. Have you tried looking for a set of used ATS-V or CTS-V calipers and aftermarket rotors to match? I think that would be a lot cheaper with the same results... I'm not sure if those are a direct fit though, so you'd have to do some research.
06-10-2017, 01:52 PM | #4 |
Drives: 2016 Corvette Z06 Join Date: Apr 2017
Just installed this kit on my car. Huge difference once they're burnished properly. Initial bite is worlds better and overall stopping power is excellent. This is a must-do upgrade in my opinion if you're planning on using your car on track on a regular basis.
You can definitely install them yourself, mine took about 2.5 hours start to finish. You'll need a decent amount of tools (floor jack, standard sockets, breaker bar, torx bits etc) but if you have them already it's not bad at all. |
06-11-2017, 08:16 PM | #5 |
Drives: Chevrolet Camaro SS Join Date: Mar 2015
Wilwood 15" same $$$
06-12-2017, 12:58 PM | #6 |
Drives: 2016 1ss Camaro Join Date: May 2016
brembo and wilwood both make big brake upgrades as well as there is always the gm/brembo kit also
Andrew Bettridge
Account Manager Extreme Dimensions 1-714-278-8000 EXT 17 andrew.bettridge@extremedimensions.com |
08-20-2017, 06:28 PM | #7 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
Theres a chance the two i know wont see your post that have the wilwood setup. But if you use the search function for this forum only there are already two posts and thoughts on their aero6 kit.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
08-20-2017, 07:24 PM | #8 | |
Drives: 16 1SS, 6-Speed, wilwoods, cat-back Join Date: May 2016
I have been very happy with them. The front kit was pretty painless to install and included stainless lines. The rears required cutting the dust shield and buying the stainless lines. I put alot of spirited canyon driving on my car (~50k miles on her) I got around 8k miles on the first set of front pads, seemed a little quick, but pads are not too costly ~$80 an axle and the front and rear is the same pad. The second set of pads seems to be lasting a little longer and the rotors seem to be holding up very well. Stopping is quite good especially with a bit of heat in them and the pedal feel is improved over the factory setup imho. Overall I was very happy with the results, I spent about 3400 on the parts and it took me about 6 hours start to finish to install them. |
08-22-2017, 11:08 PM | #9 |
I have 2,000 miles on my 2017 ZL1. I am replacing the brake pads with Power Stop Z26's to lower brake dust. Do I need to prep my rotors before install, like sanding? If so what is a good method?
08-26-2017, 09:41 AM | #10 | |
Drives: 2017 2ss, m6 Join Date: Jan 2017
I went this route over the GM route simply for replacement parts. I can get rotor parts and pads easier from my distributor and at reduced costs. There are absolutely things that I like better with the Wilwood kit over the GM/Brembo kit...but there are things that I like better about the GM/Brembo kit as well. If you are interested in more details about this route let me know and we can chat about the pros and cons of this kit. |
09-14-2017, 08:52 PM | #11 |
Drives: 2016 1SS Join Date: Jun 2016
Would like to hear more on the 6 pistion options. I've got the 2016 SS with the stock 4 piston Brembos. I feel like bone stock their stopping power is good, but I get fade pretty bad near the end of a 20 min track session at Heartland Park.
Swapped the stock pads to Power Stop Z26 and after a single session I'm way disappointed in the new pads. Much less bite than the stock pads and the fade is even worse. Looks like back to OEM at a minimum or possibly the Raybestos ST43s that people seem to like. Also had real pulsing problems despite turning the rotors and strictly following the bed in procedure on Power Stop's website. My question is I have also had some overheating issues and wonder if the larger rotor, and calipers will make a big difference. Stopping power on the 4 pistion Brembos was good on the OEM pads until the brakes were really heat soaked and then I'd get a fair amount of fade. I'm wondering about some of the new big brake kits or potentially building something with take offs. I've heard the ATS/CTS-V brakes might be an option or the stock Z06 Corvette brakes? Anyone tried any of those options? |
09-14-2017, 09:57 PM | #12 |
09-14-2017, 10:25 PM | #13 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
How/why is this a recurring theme? PowerStop Z26 are STREET pads... NOT trackday pads... Of course they're going to be horrible on a road course...
09-26-2017, 09:49 AM | #14 | |
I didn't expect them to be race pads, but I was at least expecting them to be on par with the stock pads. They don't even have as much bite on the street in normal driving conditions. And the stock pads held up fairly well on track until the brakes were really heat soaked, the Powerstops had significant fade within in lap or two. Best way I can describe is if stock was a 100% baseline, 90% at about 10 min, I was maybe down to 70% by the end of a 20min session on the stock pads. The Powerstops started out at about 70% cold, were down to 50% in 5 min and down to 40 or less by the end of the session. |
