06-03-2017, 04:55 PM | #1 |
Drives: Camaro 2017 1LE Join Date: Feb 2016
Stereo Upgrade part III
I decided to drop 3500k on a stereo audio front speakers, pro install etc the probably was when I tested it it sounded horrible would break up upon turning sound up ,,, everything was off. So the installer a PRO shop said we will put your stock system back. walked away
I really miss my stereo in my C7 corvette I don't think it is matchable the 2ss doesn't even sound near the C7 IMO. I just want a mild speaker upgrade and want to know what does the shop need to do to get the MYLINK system to not corrupt the signal? I think just a speaker swap could just get me 20% better sound just a bit louder and a bit more bass than it has .... IM not gonna play around with another 3500 system to have it fail and suck advice? |
06-03-2017, 04:58 PM | #2 |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Did you get your $3500 back?
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
06-03-2017, 05:24 PM | #3 |
Drives: 2016 Camaro 2SS Join Date: Sep 2015
I just had a complete system installed....dash door and rear side speakers...2 12 subs and 2 amps.....I agree..results can sound bad...I originally had them use a fix-86 to create a flat output from the bose amp signals but could never get the calibration to work correctly to get sound the way it should...it had a really weird tonal out of phase sound....i had them switch to a Rockford Fosgate 3sixty.3 ..does same thing as fix but way more flexibility with assigning inputs to outputs ,summing channels and a 1/3 octave eq to really fine tune...i have hours playing aound with config to get eq and levels set correctly..finally got sound really close to where I think it should be..I think to get it sounding better would be find a shop with a rta unit to set eq using pink noise.. one nice thing with Rockford piece is thar it has remote for input levels (to lower chime sound down for daily driving), bass output level and also 4 ed presets on the remote
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
06-03-2017, 05:46 PM | #4 |
Sarcasm Personified
Drives: 2017 Charger R/T Scat Pack Join Date: Dec 2015
I thought you were fighting to get rid of your car because of bad detail job? So you dropped $3,500 more into it? I'm confused.
06-03-2017, 06:08 PM | #5 | |
Drives: None Join Date: Oct 2016
06-03-2017, 06:56 PM | #6 |
Drives: '15 SS Join Date: Sep 2012
Who the **** spends that much on speakers??
Follow My Car on INSTAGRAMhttp://www.instagram.com/forb1dd3n_ss
06-03-2017, 07:22 PM | #7 |
Drives: 2016 Camaro 2SS, Nightfall Grey Join Date: Nov 2012
Use the 3500 on a louder exhaust, so you don't even worry about your stereo.
2016 Camaro 2SS, Nightfall Grey,
MRC, NPP, S/R, Nav, A8, E-Force Supercharged. |
06-03-2017, 09:26 PM | #8 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
First company to develop an interface to translate the MyLink data interface signal to analog RCA full range audio output to bypass the Bose amps gets my money.
06-03-2017, 10:00 PM | #9 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
I think you'd have better luck opening the bose amp and finding the demuxing chip that takes the audio from the MOST data stream and sends it to the amp, then cut those traces and solder on a wire with RCA connectors drilled into the bose amp casing.
06-04-2017, 01:52 PM | #10 | |
I bet there are ST micro amps in there and the spec sheets on those are easy to find. |
06-04-2017, 02:09 PM | #11 | |
Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
3500k would be 3,500,000 or 3.5 million. If you're going to bust balls at least get it right
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
06-04-2017, 04:57 PM | #12 | |
06-04-2017, 04:59 PM | #13 |
I had the bola S type with x pipe and wanted louder Im waiting on Atak 3 inch Npp coming out... Honestly I miss the stereo in my c7 it was part of my driving experience ..... I really enjoy a clear great sound it creates a visceral experience
06-04-2017, 05:00 PM | #14 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
I don't have a 6th gen but how does the Bose system compare to the 5th gen Boston Acoustics?
