04-22-2017, 10:28 PM | #1 |
Drives: 2016 2SS Camaro fully loaded. Join Date: Nov 2016
Dead ventilated seats?
Anyone else had this happen? Checked rear fuse box and fuse seems to be fine. Both seats don't put out any cold air flow at all like they used to, or any airflow for that matter.
04-22-2017, 10:53 PM | #2 |
Lovin the growl...
Drives: 2018 2SS Join Date: Mar 2017
Is there anyway to reset that? Cause I sometimes feel it's not working but then other times...
04-22-2017, 11:03 PM | #3 |
Just a fuse as far as I know.
04-22-2017, 11:47 PM | #4 |
Lovin the growl...
Thanks!
04-23-2017, 08:41 AM | #5 |
nice strat...shouldnt a 2016 be under bumper to bumper warrantee? unless you have a lousy dealer id let him check it out.
04-23-2017, 10:11 AM | #6 |
Drives: Civic Join Date: Nov 2016
Does the AC need to be switched on for the ventilated seats to work as well?
I noticed once while using my AC i used the ventilated seats and it worked fine, was cool. Then I switched off my AC but ventilated seats were still switched on. They were cool for a while then noticed that it was just not working. |
04-23-2017, 12:18 PM | #7 |
Drives: 2017 2SS M6 Join Date: Apr 2017
Pretty sure the A/C needs to be on
04-23-2017, 12:27 PM | #8 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
A/C does not have to be on!!! It MIGHT help to push cold air to the floor and then turn on the VENTILATED seats, They are not A/C seats, Just fans under them to blow a LITTLE air up through them.
04-23-2017, 12:56 PM | #9 |
Having the A/C blow cold air down to the floor certainly helps
04-23-2017, 02:19 PM | #10 |
Custom Black FiFTY
Yes they won't work unless there is cold air below the seat. They do not have AC in the seats.
Wanted a F1FTY edition but decided to make my own
04-23-2017, 02:56 PM | #11 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Not sure about above post. I never hardly run my AC, but run the cooled seats and they work fine with out AC on.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
04-23-2017, 05:04 PM | #12 |
Drives: 2016 2SS, 2008 HHR ECTO-2H Join Date: Aug 2009
They work no matter what temp your vehicle is set too and whether or not the hvac is turned on or off.
Many times when its not to hot outside I just have the windows down and the vented seats on. Even though its warm air blowing on my back it works tremendously and prevents sweat.
2016 Camaro 2SS. Hyper Blue, Ceramic White, Auto, MRC, and NPP.
1100 - 9/25 2000 - 9/28 3000 - 9/30 3100 - 10/27 3300 - 10/28 3400 - 10/29 TPW 11/09 3800 - 11/10 4300 - 11/24 4B00 - 11/25 4200 - 12/5 5000 - 12/7 6000 - 12/11 |
04-23-2017, 05:59 PM | #13 |
Drives: 2016 2SS Hyper Blue Join Date: Oct 2015
They are garbage.
04-23-2017, 06:45 PM | #14 |
Drives: 2016 2SS, Summit White, A8, NPP Join Date: Apr 2013
Video where guy has similar issue as you describe. See if his fix helps you.
https://youtu.be/spccxxixUYk |
