04-20-2017, 07:25 PM | #1 |
Drives: 2017 1SS A8 Nightfall Gray Join Date: Feb 2017
E85 Lesson needed
Finally found a station that sells ethanol near me ,the pump read flex fuel 51%-83% is this what everyone is using or is there a specific E85 pump? How would you ever be consistent at the drag strip if one time you have a certain percentage next time another?
04-20-2017, 08:02 PM | #2 |
Drives: 2016 1SS, 2017 JKU Wrangler Join Date: Mar 2016
It varies location to location. Both pumps near me are consistently 70-80%. It varies seasonally, I don't think you'll run into a situation where it pumps 70% 1 week and 51% another week.
SLO 1SS - sold
1SS MRC NPP 6MT 2018 Ram Rebel 4x4 5.7 |
04-20-2017, 08:20 PM | #3 |
Probably tired right now
Drives: 1Lap1LE | EV6 FE | 18 F150 Join Date: Sep 2010
Also if you have the flex fuel kit installed (and of course, a proper tune) the % content can vary and the ECU will compensate.
-Seven
'17 SS 1LE - 1LAP 1LE (Now with more 427!) '18 F150 Platinum Powerstroke diesel '22 Kia EV6 First Edition '18 RS3 (1 of 2) Cumulus Blue '24 911 T (ordered) Formers... '19 RS5 Sportback Sonoma Green | '07 Cayman S 6MT | '16 Audi S3 Prestige Viper Green (APR Stage 3+) | '19 Mustang Shelby GT350R | '17 SS 1LE MBM 575whp all-motor |
04-20-2017, 08:27 PM | #4 |
Drives: 2016 Camaro SS Join Date: Oct 2016
That is the correct pump. I have not seen a pump lower than 78% in NC and FL. The northern states may be lower in the winter due to cold start issues (this the change to 51% as the minimum).
04-20-2017, 08:28 PM | #5 |
How do you know what percentage your getting from the pump and what are the horsepower differences for say every 5 or 10 Percent
04-20-2017, 08:48 PM | #6 |
The scan tool (HP Tuners or nGauge) will report the ethanol percentage. The Flex Fuel sensor allows the ECM to know what the percentage is in real-time.
I can't really give a HP vs percentage relationship as I have not tested this. |
04-20-2017, 08:54 PM | #7 |
Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
3 fillups from 2 diffrerent stations, never been above 76 in my area
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
04-20-2017, 09:48 PM | #8 |
So its correct to say the flex fuel kit horsepower gains are going to vary depending on the ethanol percentage, What are the numbers on the average hp gains most people are seeing ? Also is it correct that I could install the kit and not tune until I finish my other boltons.just so I dont use ethanol until it's tuned
04-20-2017, 09:58 PM | #9 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Poor mans method I used testing a few stations in the area. This came out of a pump at a station about 20 mins from me. The station thats a mile away tested at 70.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
04-20-2017, 10:48 PM | #10 |
Drives: 2010 HD D/A, 2015 Z06, 2016 2SS Join Date: Aug 2016
sub'd
2016 Hyper Blue A8 2SS
GM Bodykit: Black MRR 017 wheels: Black OEM Blackout tail-lamps OEM SEMA Grille 35% window tint Black glow-tie BMR Suspension (Pretty much everything) ACS rear-deck spoiler Rotofab CAI Lolly-pop red rotors by Madison Powder Coating |
04-21-2017, 07:41 AM | #11 |
Drives: 18 Silverado 1500 Join Date: Dec 2015
For race days, you could also order some higher percentage fuel and fill up in your driveway. At least that's what my friends do. I just run whatever I get from RaceTrac next to my house. I'm not that serious about setting records and love the fact that my nearly stock car runs strong 11's at the track.
04-22-2017, 09:55 AM | #12 |
Drives: 2016 Chevy Camaro Join Date: Jun 2016
I haven't been able to get passed 59% on my first two fill ups here in Dallas Tx. I'm told there's a Krogers in Irving that's consistently in the very high 70's to sometimes 80% so I'm heading over there shortly. I'm an e85 addict plain and simple. The smell, the hp.... I can't go back to 93. I have it in there now and I hate it. It just doesn't have the same gitty-up as the Ewhatever. I will fill up on my way to drop it off for a few torque converter warranty issues...
04-22-2017, 11:04 AM | #13 |
I use the Kroger at Coit & 121. It's been consistently 75% for me the last month or so (4 fillups). I've seen it as high as 82% in the past.
If it's advertised as E85, by law it's supposed to be at least 70%. Also, if you're in the process of switching from E10 or gas, run it to almost empty. Put about 5-10 gals of E85 in. Run it to almost empty, like on fumes. Then fill up. You should be right near what the pump is actually spitting out. Last edited by bigsapper; 04-22-2017 at 11:14 AM. |
04-22-2017, 05:24 PM | #14 | |
