Old 04-11-2017, 04:28 PM   #1
exxit
Drives: 2016 1SS D1SC Methfed Lowered Wrapd
Slow crank but always start (sometimes)
Figured this belonged here instead of General....
The car is slow to start at times. Read in a different thread that they found negative wires to be the root cause.
Any suggestions what the best way to identify these wires would be? I'm avoiding going to the dealer because the problem is tough to recreate on demand and the car is procharged now :P
To add a footnote, it isn't the standard "long crank" that DI engines exhibit. It's a more Chug (PAUSE) chug (PAUSE), chugchugchug and good to go. Like a car with a low battery would do. But battery never shows issues otherwise. Haven't checked voltage outside of display on dash.
exxit is offline   Reply With Quote
Old 04-11-2017, 05:57 PM   #2
Subperfect
Subperfect's Avatar
Drives: 16 Camaro
doubt the procharger has anything to do with the problem took mine in Monday with the same problem having a vortech on it.
http://www.camaro6.com/forums/showthread.php?t=491006
Subperfect is offline   Reply With Quote
Old 04-11-2017, 06:48 PM   #3
SliverATX
SliverATX's Avatar
Drives: 2018 Camaro 2SS
Sometimes I have the same issue when restarting after 10-15 laps at the track. Is the charging system under driven at WOT?
SliverATX is offline   Reply With Quote
Old 04-11-2017, 07:18 PM   #4
crazydmc
ummmm
crazydmc's Avatar
Drives: 2016 2SS M6 Nightfall w/Blk Wheels
i'm going to check my cables.
the heat makes it harder to start.... I think the distance between the battery and starter is likely an issue.... every cable connection must be perfect to get enough amperage to the starter.
crazydmc is offline   Reply With Quote
Old 04-11-2017, 08:07 PM   #5
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Heat Soak
If your starter easily cranks a cold engine, but “drags” or cranks very slowly when hot, there may be a “heat soak” problem
Assuming that the diagnosis results are within acceptable ranges and the starter cranks fine when cold, it is quite possibly a “heat soak” condition.
What exactly is starter “Heat Soak”? Without getting into the physics of thermal conduction or Newton’s law of convective cooling,
it is simply a matter of the starter absorbing and retaining heat from under-hood sources such as the exhaust manifold.
This absorbed heat adds resistance to the electrical conductors inside the starter. The additional resistance results in the starter requiring more amperage than it normally does when cool.
Once under-hood heat warms the battery, cables, and starter, a “tipping point” is reached concerning the overall amount of resistance a starter can accept
(and still function properly)
http://www.knowyourparts.com/technic...hot-heat-soak/ More here
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 04-12-2017, 10:05 AM   #6
exxit
Ugh the saga continues! lol
I'll take a peek at the wires themselves, but they look solid on the terminals.
Could possibly be heatsoak, in which case i'll look around the starter to find any obvious sources.
I'm wondering if anyone who found the grounding issue remembers which wires they replaced.
Old 05-05-2017, 05:45 PM   #7
Cdflyer
Cdflyer's Avatar
Drives: 2016 1SS 6speed
Any luck diagnosing this yet? Mine has been doing the same as of late.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials.
Cdflyer is offline   Reply With Quote
Old 05-05-2017, 08:50 PM   #8
franksredhot
franksredhot's Avatar
Drives: 2016 Red Hot Camaro 1SS A8
Same problem here but last week I had to hit the start button a couple of times before it started. It is worse than last summer so I do think at some point it will leave me stranded when the weather gets hot. My dealer never seems to find my problems. Just because they don't notice the problem doesn't mean it isn't happening. I can't stand my Chevy dealer. I'm going to try a different one.
franksredhot is offline   Reply With Quote
Old 05-11-2017, 04:41 AM   #9
SGDM
SGDM's Avatar
Drives: 2016 2SS
Mine does the same thing when I am at the drag strip. I have checked all the connections and wires...
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 05-15-2017, 02:10 PM   #10
exxit
Another member mentioned that this issue was due to "two ground wires" with no more info than that really.
I've definitely narrowed it down to it being an issue ONLY after the car has been warmed up and driven. Every consecutive start while the car is hot makes it a bit tougher to start, and the symptoms are completely gone if the car has had time to cool off. Us west coasters and midwesters are going to get hit sort of hard in the coming months.
Mine has never NOT started as of yet, and for now I'll let it be. Next oil change I'll be doing the gear oil (for shits and giggles and preventative maint.) I'll take a look at the starter location and see what, if anything, i can do about the heatsoak
Old 06-05-2017, 02:48 PM   #11
exxit
Heat related issue number 2, just bumping this up to see if anyone found a work around or fix they applied and are happy with.
I noticed my buddies ZL1 cranks with a whole different noise (i know i know, different motor essentially) but would an LT4 starter work? Am i reach for stupid straws at this point? lol
Old 06-10-2017, 06:09 PM   #12
franksredhot
I was in the dealer again and they found nothing. Getting warm in NYC, yesterday I barely started after driving around for a while. I think at some point I'm going to be left stranded.
