04-08-2017, 05:09 PM | #1 | |
Drives: 2012 Summit White SS/RS M6 Join Date: Oct 2016
Changing fluid in our tr6060 manual transmissions
hey guys, i made a how to on changing trans fluid in a 2010-2015 camaro SS with the TR6060 M6. enjoy and let me know if you have any questions!
2012 SS/RS Summit white.
Rotofab-Stainless Works 2" long tubes & 3" "Retro Catback", BTR stage 3, platinum springs and pushrods. previous power was 428.9, before the cam. awaiting dyno time |
04-08-2017, 05:54 PM | #2 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
Nice video. Thanks for sharing.
04-08-2017, 06:12 PM | #3 |
Does Zl1 have same tranny?
04-08-2017, 08:07 PM | #4 |
Also, what happens when you mix the two different tranny fluids together? one stuck in lines and new fluid... tried that with break fluid different kind learned it the hard way...
04-08-2017, 08:27 PM | #5 | |
I have experienced much smoother shifting with the redline fluid tho, that's a fact.
04-08-2017, 09:10 PM | #6 |
Si Vis Pacem, Para Bellum
Drives: 2010 Camaro 2SS Join Date: Apr 2010
You should have used jack stands. There is not a lot of room under there if the jack failed.
"Children should be educated and instructed in the principles of freedom." --John Adams |
04-08-2017, 09:16 PM | #7 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
Thank you Padilla, will be doing this after my 2 day track day in May
"Make yourself sheep and the wolves will eat you"
04-08-2017, 10:25 PM | #8 |
Drives: 2010 2SS Join Date: Mar 2017
04-08-2017, 10:29 PM | #9 |
Drives: cars Join Date: May 2011
So a video on how to die when your jack fails.
04-09-2017, 02:42 AM | #10 |
Drives: 2014 1SS/RS LS3 Join Date: Jul 2012
Another tip. Crack the fill plug lose before removing the drain plug. It will drain faster. And like mentioned, USE JACK STANDS. Especially if your making a how to vid for other to follow. Safety first!
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
04-09-2017, 09:40 AM | #11 |
you know, you guys are absolutely right about that. normally i do use jack stands but i didnt this time around, i have a good jack but i should have still used them. i will in the future any time i get under the car
04-09-2017, 11:17 AM | #12 | |
Drives: Miss Con Ception Join Date: Aug 2016
Slide one under the car even if you don't set the car on it.
2011 1SS/RS LS3 CGM
04-09-2017, 11:53 AM | #13 |
I refilled mine from above using some clear PVC tubing and a funnel.
Very easy, let gravity do the work.
'14 1LE, Recaro, Cammed, Headers, Hi Flows, CAI, Tuned, 486 RWHP
https://www.youtube.com/watch?v=H57UfKCO0EY&feature=youtu.be |
04-09-2017, 07:53 PM | #14 |
That's a great idea too
