Vararam
Old 03-30-2017, 05:22 PM   #1
Oscarc2011
Drives: Camaro V6
Unlock button & trunk release button issues
Hello fellow members, I recently noticed that my unlock button and trunk release button in the car stopped working. I can lock the doors, but nothing happens when I press the unlock button. Same with the trunk release on the drivers side panel. Is there a troubleshooting method I could use to see if it's a faulty wire or switch? Or how can I test to see what the problem is ?
Oscarc2011 is offline   Reply With Quote
Old 03-30-2017, 06:08 PM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
Flip the back seat down if you have a coupe and crawl in and pull the handle to open it first. I think there is a upper switch for the light, its been a while since I read a post on this., but its would seem the wiring to the lock would be the first place I would look to see if something happened to the wiring harness. You did not mention if its not working on the remote FOB. And I would check the fuse boxes and take out and replace or at least visually inspect the fuse by removing, there is also a fuse box in the trunk under the passenger sail panel cover on the right of the trunk that's where fuses for NPP dual mode exhaust is and other things , then there is the fuse box in the engine bay of course. Good luck maybe a search on the internet could yield some results.
christianchevell is offline   Reply With Quote
Old 03-30-2017, 06:29 PM   #3
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
How old is the battery ? What year is your car ? As batteries get weak the cars start to do some weird crap some times .
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 03-30-2017, 06:39 PM   #4
Oscarc2011
Drives: Camaro V6
I forgot to mention that everything works fine with my FOB, I just have the issues when I try to use the buttons in the car. I'll definitely check out the trunk area and inspect the fuses, thanks for the advice !!
Old 03-30-2017, 06:40 PM   #5
Oscarc2011
Drives: Camaro V6
I just replaced the battery last year, so I think it should still have some juice in it. It's a 2010
Old 03-31-2017, 11:59 AM   #6
lt1power
Drives: 2011 2SS RS
My trunk release would not work. The switch in the door was bad. Replaced and works fine now.
lt1power is offline   Reply With Quote
Old 03-31-2017, 04:59 PM   #7
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Second vote for the door switch. If the FOB trunk release works, then all wiring, fuses, etc. to the trunk release mechanism are good. It's either a faulty switch, or the electrical plug at the back of the switch has come off.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 03-31-2017, 05:10 PM   #8
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Check if both door switches are doing this. then check the one under the radio.
Chances are its only the wiring going to one door.
Did you buy this car used? if so someone probably put a T-Tap on a harness that has broken the wires.
Good luck
GVA 45TH 2SS is offline   Reply With Quote
Old 09-18-2019, 11:42 AM   #9
Shep0001
Drives: 2013 2lt RS
Did you find out?
Did you ever figure out what it was that was going on for it to do that because my 2013 camero doing the same thing lock buttons work but unlock buttons or trunk button is not but the key fob works fine so im trying to figure out what i may have been?
Shep0001 is offline   Reply With Quote
Old 09-18-2019, 08:06 PM   #10
Rob10CamaroSS
Drives: 2012 ZL1 Redline Phase 4
Wow what dijivu, I just went through EXACTLY what you described; Trunk release button on door didnt work & couldnt unlock it with door button. PS my batt was from July 2018 and I hadn't had a single batt issue in the yr I've owned it
Short answer is YOU NEED A NEW BATTERY
Long answer is my two recent threads...
Trunk Release Button on Door Not Working Question
Lots of weird problems out of no where HELP
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
Rob10CamaroSS is offline   Reply With Quote
Old 07-05-2023, 12:47 PM   #11
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
My trunk button on the door was intermittent, then just quit. Never thought this was the answer, but replaced my battery and now the trunk button is back to working. Who knew the 8 year old OE battery was an issue!
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
