![]() Drives: Civic Join Date: Nov 2016
Service Brake Assist Message (already browsed older thread)
Two threads already exist for this issue but none of them have any posts where the root cause of the issue was figured out or the dealer fixed it.
Last night I was driving at around 20 mph turned into a parking lot, stopped to back into a spot and the brakes felt weird when I pressed them, like I had to push them harder than usual and some sort of friction and then this message popped up on the dash "Service Brake Assist". The issue went away when I shut down my car and restarted it after 10 mins. Wanted to know if any of you have experienced it recently and is there a fix for this? I've contacted the dealer and waiting to hear from them. |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
mine activated upon me (sorta hard) on the brakes upon slowing down from 110ish. took it to the dealer the next day and verified, nothing came about it and they just reset the code. didn't tell me what the root cause was.
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
#3 | |
. They'll just have a joyride in my car since this cannot be reproduced on the fly.It's scary to think the brakes failing like this on the freeway at really high speeds!
I went to the dealer and told them about this issue. They said there was a bulletin form GM about this issue and have reprogrammed the module with GM's update. attaching a picture of the same. Anyone who is still having this issue can show this information and maybe the dealer can help you out.
#5 | |
![]() Drives: 2017 RS CAMARO V6 Join Date: Jun 2018
![]() Drives: 2016 Chevrolet Camaro 2SS Join Date: Jun 2020
I just experienced this issue and thanks to checking in the forums here had it taken care of with a service bulletin. I understand this is an old forum, but with low mileage cars still out there, this issue is still very real in 2020 and I wanted to help anyone I could.
My brake assist warning came on and I lost about half my braking pressure and it felt that ABS was on 100% of the time. This is mentioned in the owners manual as normal behavior when the service message occurs. I turned the car on the next day and the issue was gone but took it for service anyway. They told me there was a service bulletin and they will simply run a diagnostic and if no issues are found other than the TSB then that's all they will charge. It happened 8 hours prior the night before the computer had all the error codes stored so they were able to pull them up without any active CEL or Error Codes. Should be a recall and not a TSB but just needed to share this as these forums are the reason I knew of the fix ahead of time. Maybe a diagnostic fee is worth the piece of mind to get the update needed rather than waiting for the brakes to fail in traffic as mine did. "Internal software fault in EBCM. Reprogram EBCM per BULL#17-NA-048" |
#7 | |
![]() Drives: 2017 ZL1 Join Date: Jun 2018
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
