02-24-2017, 12:34 PM | #1 |
Lights in glove box
Does anyone know if there are stock lighting in the glove box? I do not see bulbs, wiring etc. I have a 2012 2 SS. thank you
02-24-2017, 01:11 PM | #2 |
More Balls Than You
Drives: 2012 2SS/RS / 1969 Camaro 427 SS/RS Join Date: Mar 2012
Nope. No wiring or lights. I think Gen5DIY sells an aftermarket one.
02-24-2017, 03:24 PM | #3 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Back in the 50's, 60's, 70's even the cheapest Chevrolets had both a glove box
light and footwell lighting. So cheap today. Those were the good old days imo.
02-24-2017, 03:44 PM | #4 |
Drives: 2010 CHEVROLET CAMARO SS RED Join Date: Feb 2017
I mean honestly how are would it be to run a wire and a bulb to the glove box.
02-24-2017, 03:48 PM | #5 |
Really now how hard or expensive could it be to run a wire and a bulb to the glove box. Crazy!!!
02-24-2017, 05:50 PM | #6 | |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Never got a good answer on that either. But we can put lights to see where to put our feet, and where to put our cups. |
02-24-2017, 05:54 PM | #7 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
02-24-2017, 06:56 PM | #8 |
WHAT RED LIGHT?!
Drives: 2011 Black Camaro 2SS/RS M6 Join Date: Apr 2011
Just think of it as less chance for parasitic loss...glovebox, hood, trunk...anything that a light comes on when open and can't tell if its still on when closed...We should be happy not to have those luxuries anymore
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
02-24-2017, 07:32 PM | #9 |
Drives: 13 Camaro Join Date: Oct 2016
02-24-2017, 10:14 PM | #10 |
I had a 1991 Chevrolet pickup that had a light under the hood that was on a cord. You pulled it out, turned it on and could use it anywhere under the hood. When done you wound it up and turned it off. I really liked that light. Agree, the good old days.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears. |
02-25-2017, 07:23 AM | #11 |
Drives: The red one Join Date: Jan 2015
When I bought my car in Feb. 2015 I could not believe it only had the one overhead light inside. I never really noticed that on the test drive although it wouldn't have made a difference. It just seems kind of ..... cheap.
I just use the flashlight app on my phone if I really need to see in the glove box. It seems kind of ridiculous, but it works. Might get around to putting a light in there one of these days. |
02-25-2017, 08:08 AM | #12 |
old school chevy rodder
Drives: 2013 2SS/RS Manual,DM exhaust,CRT Join Date: Jul 2012
to counter lighting problems I went to gen5diy.com and looked up and installed under dash lighting by buying $20 strip LEDS from the local self adhesive strips on them and attaching them up under the dash on both sides then taking off the kick panel for the passenger and tapping into the two wires for the interior lighting leaving me with constant low level lighting shining on my feet to be able to see...a must when your a manual and more important than the glove box. I would point out the harness connection is rather tight to get it loose and tap into the wire it will be right next to the harness connection and sufficiently taping the thing is very important to not short out, but its totally worth it to do and is must do mod I believe. Good Luck....foot well lighting is more important.....and my dome is a brick of LEDs colored red... the directions on the sitw showed me the proper number and color of the two wires to tap into and long ago there may be threads on here showing this.
02-26-2017, 08:52 AM | #13 | |
ever needed the trunk light but would have appreciated footwell lighting thousands of times in the past 8 years. Added my own: |
02-26-2017, 09:01 AM | #14 |
Drives: 2015 ZL1 Join Date: Jun 2015
Yep, I remember that in my 91 SS pickup!
2015 ZL1 M6
