Old 02-06-2017, 08:44 AM   #1
TarponTime
TarponTime's Avatar
Drives: 2000 Camaro SS SLP
gen 6 ZL1 vs gen 5 z28 Nurburgring
Not sure about you guys but it seemed like the gen 5 was winning before the rain hit... Great side by side!
TarponTime is offline   Reply With Quote
Old 02-06-2017, 02:11 PM   #2
Diggitydog
Drives: 2017 ZL1 Nightfall Convertible M6
No it wasn't the ZL1 acceleration was way ahead of the Z28. The Z28 was slightly edging on the early corners, maybe. ZL1 was gaining huge as soon as it opened up.
Neat comparison. Thanks for sharing.
Diggitydog is offline   Reply With Quote
Old 02-06-2017, 04:26 PM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
I really like this video!!!
The Z/28 was the benchmark set by engineers for the new ZL1. They will both put up similar lap times but in different ways...the Z/28 can carry a bit more speed through the tighter corners thanks to its tires...but the ZL1 can keep up in all other metrics, including braking...and absolutely blows it away with power and speed on the straights and sweepers.
I think even in the dry, the Z/28 would be a 6-8 seconds behind the '17 ZL1. We'll likely never know...
Here are some test data points I lifted from Motortrend:
......................................2014 Z/28.........2017 ZL1
Transmission........................M6............ ......A10
Weight (lbs)........................3858................3 926
Quarter Mile (sec)................12.3.................11.5
0-60 (sec)............................4.0.............. ...3.5
Braking 60-0 (ft)...................97...................96
Average Lateral G.................1.06...............1.06
MT Figure 8 (sec)..................23.6................23.1
Both are simply amazing.
Old 02-06-2017, 05:03 PM   #4
big dave
Drives: 2017 ZL1
The ZL1 was ahead most of the course, but the Z28 was clearly ahead until it started to rain. You can definitely see how it started sliding around as the windshield was getting wet. Though it's probable the ZL1 would still be faster, I think the lead may have only been 3 - 4 seconds at best.
I've watched this video several times before, it's still fun watching what these guys can do that I can't even do on playstation.
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 02-06-2017, 05:12 PM   #5
mr965
mr965's Avatar
Drives: ///M3
A friend of mine just bought a Z28. After I receive mine and get it broken in I hope to see him at the track. Then we'll get a comparison
mr965 is offline   Reply With Quote
Old 02-06-2017, 07:27 PM   #6
URBAN LEGEND
URBAN LEGEND's Avatar
Both cars are great machines for certain.
🔺22 RS E TRON GT
🔺21 Model S Plaid
URBAN LEGEND is offline   Reply With Quote
Old 02-06-2017, 07:45 PM   #7
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Originally Posted by big dave View Post
The ZL1 was ahead most on most of the course, but the Z28 was clearly ahead until it started to rain. You can definitely see how it started sliding around as the windshield was getting wet. Though it's probable the ZL1 would still be faster, I think the lead may have only been 3 - 4 seconds at best.
You are correct the Z/28 was ahead right before the rain started. It would have been great if the rain wouldn't have started to have a closer apples to apples comparison. The ZL1 is impressive. Good job GM!
2cnd chance is offline   Reply With Quote
Old 02-06-2017, 08:31 PM   #8
hotlap
hotlap's Avatar
The ZL1 was a little ahead until just before 6 minute mark and then the Z/28 got a slight edge. They were so close!
Then they hit the straight and the ZL1's speed took over and it's win was certain regardless of the rain. More power to weight
Ronald Reagan -
Old 02-07-2017, 01:39 AM   #9
mr965
mr965's Avatar
Drives: ///M3
I'd be curious to see the effects of the same square tire setup on the ZL1.
Old 02-07-2017, 09:39 AM   #10
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
This is your answer of why the Z28 is almost as fast as a car that's lighter (I'm pretty sure at least) and got 145 more HP.
But let us not forget in this discussion that even if the ZL1 would to TIE with the Z28 on the Nurburgring, the ZL1 would still be a far far far better car. For straight line it wouldn't even be close, Z28 really runs out of steam with only 505 HP and a lot of aero. On a road the ZL1 is going to be way more comfortable, variable personalities with 3 different drive modes and 5 different PTMs coupled with a M6 with active rev match, launch control (Z28 may have this), line lock, or the A10 with near instant shifts...Plus the interior is far and away better. Not to mention it's a lot easier to mod a factory supercharged car for decent numbers, sure you could beat a bolt on LT4 by pro charging a LS7, but I'd not be interested in doing such a thing.
I could keep on going, but no 5th Gen is going to be as good as a 6th Gen
I've gotten the same feeling when I had a C6 Vette and the C7 came out, same thing that's happening now. I feel the need to move on/up, some people don't, that's fine.
Chevy is the real MVP here tho
Old 02-07-2017, 09:46 AM   #11
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
Road course no doubt, it will be interesting to see how they compare in the 1/4 non-stock.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 02-07-2017, 12:01 PM   #12
KMPrenger
KMPrenger's Avatar
Originally Posted by Diggitydog View Post
No it wasn't the ZL1 acceleration was way ahead of the Z28. The Z28 was slightly edging on the early corners, maybe. ZL1 was gaining huge as soon as it opened up...
The Z28 actually caught and passed the ZL1 until the rain hit and the cars entered the long back stretch where the ZL1 could put more distance on it.
I've watched this video a while back, and I think take away(s) from this for everyone should be that 1) The Z/28 is clearly faster than the "official" time it is credited for, as the fact that it caught and passed the ZL1 in the twisties means on dry pavement it would have gained more time on the ZL1 at the end of the course. I think it would have only been 4 seconds behind. Not the 8+ seconds the official times show. 2) If the 6th gen Z/28 can put the power down as well, or better than the 5th gen, be lighter, and have that same level of grip and braking.....HOLY COW is it going to be a track monster.
2014 Z/28 is around 100 lbs lighter than the new ZL1.
Old 02-07-2017, 01:18 PM   #13
ron scubadiver
Drives: 2017 2SS Hyper Blue
175 mph, take off speed for a big Jet.
Check out my photo blog: https://ronfromtexas.wordpress.com/
ron scubadiver is offline   Reply With Quote
Old 02-07-2017, 03:23 PM   #14
Mário Matos
Drives: Camaro ss
z/28
HELLO FRIENDS ,
I WOULD LIKE TO HAVE SEEN THE TIME TAKES OF THE Z / 28 ON THE SAME DAY OF THE G6 ZL1 AND WITH MANUAL CHANGE, BECAUSE IT'S A COVARDY FOR THE Z / 28 WITH MANUAL CHANGES COMPETING WITH ZL1 WITH SWING ON THE STEERING WHEEL IS MY OPINION.
Mário Matos is offline   Reply With Quote
