![]() ![]() ![]() Drives: Camaro 2017 1LE Join Date: Feb 2016
Brake noise?
Noticed my brakes are squeaking only about 800 miles on car, is it just new pads? or do they need any adjusting? thanks!
I used to be Dragoneye...
have you Bedded/burnished them, yet?
![]() ![]() Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
large, high performance brake often require a bedding process....
go find a deserted country road with no traffic or bears..... hit 50-60 mph... then do a 90% effort stop without triggering ABS.... do this about 5-6 times... then drive for a while to cool brakes... your brakes are now bedded.
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 |
#5 | |
This is similar to the description in the owners manual, under "Driving and Operating": |
#6 | |
#7 |
![]() Drives: 2011 Cayman R 2017 1LE Join Date: Jan 2017
If you are going to track the car, I would recommend you get them VERY hot during this process.......They will last much longer and you won't suffer from the "warped" rotor pad deposits.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Brake squeal is a badge of honor
"KEEP THE FAITH"-Fbodfather |
#9 |
i looked through all the break in stuff on the manual ! didn't say to do that! I missed the driving and operating part! will do ! thanks guys
#10 | |
You bet. When you're done, report back if you could. I'm curious for your thoughts...I've noticed the brakes bite a bit harder when you first press the pedal after this process, and as mentioned earlier - lasted longer on the track. |
#11 |
![]() Drives: 2017 Camaro 1LE Join Date: Sep 2016
Could easily be bedding them correctly but I have also heard from my salesman that a bulletin was released about squeaky breaks for the SS 1LE package. Long story short, it may not be you Chaos, it could be something GM is aware of and may release something to combat it.
2017 Hyper Blue 1LE
#12 |
![]() Drives: 2019 ZL1 1LE, MN6, SGM Join Date: Jun 2016
FWIW, the brembos on my GS- same calipers- have always been silent.
#13 |
![]() Drives: 2017 2SS Camaro Join Date: Mar 2015
How can you tell if the brakes have been burnished? I bought mine used and the squeal is down right embarrassing. I find myself downshifting and only using the brakes when I absolutely need to then i pump them because the damn squeal. pads are fine....lots of meat left. Will doing this procedure help?
2017 Camaro 2SS, K&N Air, Borla S-Type, Cat Delete, 1LE replicas, Hotchkis Swaybars, Eibach Springs. ALL BMR arms, end links, chassis braces and cradle lockout. Hurst shifter.
#14 |
![]() Drives: 2018 ZLE, 2023 C8, IMSA MX-5 Join Date: Jul 2019
You will definitely see a color change to the rotor in the pad sweep area. A bright and shiny rotor is not burnished. You will also smell when they are burnished if done correctly. Once you smell the burn, they are just about done. Once hot,very important to cool down the rotors without using the brakes or parking the vehicle.
On the other hand, thinking a new service where anybody can send me their front rotors with return shipping prepaid and I will gladly burnish them at the next track event FOC. Also willing to exchange a new set of quiet low dust ceramic pads for those crusty, dusty OE pads. Guaranteed no squeal deal...... Last edited by NorthGeorgia; 09-08-2020 at 04:50 PM. |
