Old 01-29-2017, 11:31 AM   #1
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
All the Facts: 2017 Camaro ZL1
Let's post all the pertinent details we know about the ZL1; along with links to threads and articles supporting the information and providing some good reading.
There's many people still that don't quite understand what the car is. Most of them are reading without accounts. I hope this thread to be useful to them.
Due to time, I'm going to start small...but please - post up any contribution you might think of!
Official Playbook for ordering
Pricing:
2017 Camaro ZL1 Coupe..................$61,140
2017 Camaro ZL1 Convertible...........$67,140
Destination Charge..........................$995
Gas Guzzler Tax (manual).................$1300
Gas Guzzler Tax (auto).....................$2100
Build and Price available at: http://www.chevrolet.com/camaro-zl1.html
Engine:
Chevy Small Block LT4 6.2L/376cu in V8
Direct-Injection, Variable Valve Timing
650 hp @ 6400 rpm
650 lb-ft @ 3600 rpm
redline: 6600 rpm
**new for 2017 includes an integrated PCV oil vapor separator, taller supercharger plenum cover for larger intercooler bricks and improved IAT cooling.
More details: GM Media Release - LT4 V8
Performance/Figures
Coupe:
0-60 (manual)...............3.7 seconds
0-60 (auto)...................3.5 seconds
1/4 mile (manual)..........11.8 seconds
1/4 mile (auto)..............11.4 seconds
Lateral acceleration........1.02 g
Convertible:
0-60 (manual)...............3.9 seconds
0-60 (auto)...................3.7 seconds
1/4 mile (manual)..........12.0 seconds
1/4 mile (auto)..............11.6 seconds
Lateral acceleration........1.00 g
Braking Distance............107ft/110ft (coupe/convertible)
MPG (city/hwy).............................12/20 (auto)
.................................................. 14/20 (manual)
Track Times
Nurburgring: 7.29.60 1LE = 7.16.04
Big Willow: 1.26.16
MT Figure Eight: 23.1
Dimensions (+/- vs LT & SS)
Width............................75" (+.3")
Length...........................190.2" (+ 1.9")
Height............................52.9" (-.2")
Front Track Width.............63.4" (+.3")
Rear Track Width..............62.0" (-1.1")
Wheelbase.......................110.7" (+0)
Wheel Offset (F/R)............20mm / 43mm
Weight (lbs)...................3883 (manual coupe)
....................................3944 (auto coupe)
....................................4113 (manual convertible)
....................................4148 (auto convertible)
Wheel & Tire Sizes
Equipment, Options, and Details
Gear Ratios...............M6.............A10
1.............................2.29...........4.70
2.............................1.61...........2.99
3.............................1.21...........2.15
4.............................1.00...........1.80
5.............................0.82...........1.52
6.............................0.54...........1.28
7..............................................1.0 0
8..............................................0.8 5
9..............................................0.6 9
10.............................................0.6 4
Final.........................3.73...........2.85
  • Electronic Limited Slip Differential (eLSD), clutch-type with hydraulic actuation. Varies between full-lock, and full-open at the computer's command...NO BRAKE INTERVENTION
  • Gen III Magnetic Ride Control Dampers: dual coil, magnetorheological fluid, "reads" the road and reacts every inch of travel at 60mph, or every 1/1000 second.
  • Forged 20x10" (Fr), 20x11" (Rr) Wheels
  • Goodyear Eagle F1 Supercar 3 tires: 285/30ZR20 (Fr), 305/30ZR20
  • Performance Traction Management Software, Wet, Dry, Sport 1, Sport 2, Race
  • Custom Launch Control, No-Lift Shift, Burnout Mode, and Active Rev Match (manual-only)
  • Carbon Fiber extractor-style hood vent
  • Full-optioned interior similar to 2SS, with black suede & leather panels, and red stitching accents.
  • Power Recaro seats w/ suede seating surfaces & heat/cooled
  • Front: 15.35" / 390cm vented, with six-piston monobloc calipers
  • Rear: 14.4" / 365cm vented, with four-piston fixed calipers
Fun Facts
  • The 2017 ZL1 has slightly smaller frontal area than the 2015 ZL1
  • All body shapes, including "overlooked" items like the bumper cover were extensively tested and formed in the wind-tunnel
  • Goodyear Eagle F1 Supercar 3 tires mark the first application of Goodyear's new design...developed specifically for ZL1 and 1LE.
  • Designers and Engineers trimmed the thickness of the front grill during wind-tunnel testing in order to reduce turbulence and increase airflow to the heat exchangers.
  • Red seatbelts are included with the following colors: White, Silver, Red Hot, Nightfall Gray, Black, and Mosaic Black. All other colors get black seat belts.
  • Al Oppenheiser remarked that the new ZL1 achieved levels of speed on the Nurburgring that necessitated using driving lines on track similar to open-wheel racers.
  • The A10 features several "easter eggs". For example, when driving in a highway gear, you can hold the downshift paddle for one second and the transmission will immediately shift into the lowest possible gear for a pass.
  • The manual transmission ratios allows the car to accelerate to 60 mph in first gear.
  • The A10 programming, in "D" includes three different levels of shift calibrations, depending on how hard the driver is pushing the car.
Major Component Origin:
  • All Camaros are assembled in Lansing, MI @ GM Lansing Grand River Assembly (or "LGR")
  • LT4 engines are built at the GM Tonawanda, NY powertrain plant and some are hand-built at Bowling Green, KY.
  • A10 transmissions are built at the GM Romulus, MI Powertrain plant.
  • All M6 transmissions are built in Queretaro, Mexico by Tremec (whose worldwide headquarters are located in Mexico City, Mexico.)
Other Documents/Resources
Owners Manual: HP ZL1/1LE Supplement - 2017 ZL1&1LE Performance Supplement.pdf
2017 Camaro Vehicle Catalogue - 2017-chevrolet-camaro-catalog.pdf
Break-in and Track Preparation Guide + Alignment Specs - 2018-chevrolet-camaro-track-preparation-guide.pdf
Old 01-29-2017, 02:07 PM   #2
Mr. Wyndham
Servicing Info
Transmission fluid
Name:  trans fluid.JPG
Old 01-29-2017, 11:28 PM   #3
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
This is a great start. Look forward to the next round of info...
Canadian ZL1 is offline   Reply With Quote
Old 01-30-2017, 05:14 AM   #4
HyperBlueX2
HyperBlueX2's Avatar
Great job!!!
Old 01-30-2017, 06:53 AM   #5
Lashu74
Lashu74
Lashu74's Avatar
Drives: 2017 ZL1
Very nice, how about the offset of the wheels
F 20 R 43
Lashu74 is offline   Reply With Quote
Old 01-30-2017, 09:51 AM   #6
camaro99
camaro99's Avatar
Drives: Angry Dorothy II 2016 2SS
How to get more "Zed L 1's to Canada...
camaro99 is offline   Reply With Quote
Old 02-01-2017, 08:04 AM   #7
Mr. Wyndham
F 20 R 43
Thanks!
Good suggestion - added it to the OP.
Old 02-01-2017, 09:36 AM   #8
We need to up your pay around here. You killed it with this one.
Old 02-01-2017, 10:24 AM   #9
Mr. Wyndham
Thanks...but it wasn't that hard.
I've been collecting little bits of information as it came out. And after I saw 5 different stickies up here, I thought it was time to put it all in one place.
(You should see my ZL1 photo library! )
Old 02-01-2017, 10:48 AM   #10
Great Info - in one place!..
...( I got good news today....)..
Old 02-01-2017, 10:54 AM   #11
DenverTaco07
DenverTaco07's Avatar
I'd like to know if on the Auto, the gear shifter has a tiptronic style mode, where you can shift up and down using the shifter, or if putting it in the +/- gate simply tells the car you want Manual paddle shifters.
I sort of assumed it would have a tiptronic style capability, but I'm not so sure. If anyone knows for sure please do tell.
Old 02-01-2017, 10:55 AM   #12
Mr. Wyndham
Yes, it does.
Old 02-01-2017, 11:03 AM   #13
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
Very nice.
I read through the owners performance supplement and that is awesome. Nice to see Chevy taking the time to make this for all ZL1 owners.
I really liked the part about the seat belts. Going to have to try that trick next time at the track.
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 02-01-2017, 11:23 AM   #14
DenverTaco07
Yes, it does.
Yup...thanks I didn't see that in the supplemental, but then realized the (other trims) Camaro has the same +/- gate. In the manual page 227:
DSC allows shifting an automatic
transmission similar to a manual
transmission. To use the DSC
feature:
1. Move the shift lever to the left
from D (Drive) into the side
gate marked with +/−.
2. Press the shift lever forward to
upshift or rearward to
downshift.
While using the DSC feature, the
vehicle will have firmer, quicker
shifting. You can use this for sport
driving or when climbing or
descending hills, to stay in gear
longer, or to downshift for more
power or engine braking.
That's awesome, I'm pretty sure this did not exist in the previous gen ZL1.
