Old 01-24-2017, 09:07 AM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JANNETTY RACING LT1 SUPER STREET BRAWLER MAKES 725 RWHP 675 RWTQ E-85 9.2 PSI
I thought i posted this but I can't seem to find it LOL
2 weeks ago we ran the 80 mm 11.2 PSI pulley E-85 combo and made 726 RWHP 701 RWTQ but fuel pressure was dropping at 6400 RPM along with power.
Further testing last Friday with E-85 and larger 85 mm 9.2 PSI pulley revealed more power on the LT4 Fuel system components and fuel pressure is holding steady to 6800 rpm.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-24-2017, 10:55 AM   #2
laynlo15
Drives: 2022 Lt1 A10
Awesome results.
Old 01-24-2017, 11:22 AM   #3
laynlo15
So, its putting out the same power with larger pulley and Lt4 system? that's really great news.
Old 01-24-2017, 11:28 AM   #4
JANNETTYRACING
It did give up 26 lbs torque at peak due to the lower boost but with a little tuning at 9.2 was able to easily make the 725.
I feel there is more in it with more timing but I am very happy with the results so we are going to leave it there for now.
Ted.
Old 01-24-2017, 01:53 PM   #5
laynlo15
Needs to go to the track this spring to see if you can put that power to the ground with some slicks or drag radials.
Old 01-24-2017, 02:12 PM   #6
aka Reckless
aka Reckless's Avatar
Drives: 2016 2SS Camaro
Is there an aftermarket CAI? Other post doesn't say?
aka Reckless is offline   Reply With Quote
Old 01-24-2017, 02:31 PM   #7
JANNETTYRACING
Stick car good driver on Slicks I predict 10.40 ET.
Factory Air box, I have it on the dyno right now with a Rotofab and will be reporting the results tomorrow.
Ted.
Old 01-26-2017, 12:03 AM   #8
JaxChris
RotoFab give up any extra?
Also, what happened to piston explosion warnings when getting close to 650, as were reported by a number of reputable shops that were working on Z51's before the 2016 Camaro came out? Does our LT1 have revised internals? No more powdered metal soup cans that are prone to fracture?
If this is your customer delivery output that you think is reliable for a daily driver, I'm floored. The ZL1 buyers are in for a serious treat if they want to do a blower and pulley swap based on the data you're showing.
Old 01-26-2017, 08:58 AM   #9
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
Nice Ted!
EFI Tuning is offline   Reply With Quote
Old 01-26-2017, 11:14 AM   #10
JANNETTYRACING
Yes sir 12 RWHP 12 RWTQ in back to back testing fully tuned.
Which forced us to run in to the fuel pump limit again on Straight E-85.
We mixed in 5 gallons of Gasoline for an E-66 and repeated the test Rotofab, VS stock air box. same results. 12 RWHP 12 RWTQ.
734 RWHP with Rotofab Red filter, we did not have a dry filter handy but expect about 3-5 more RWHP with a Dry filter.
Regarding your stock internal question Advantage LT-1 due to higher compression we don't have to lean on the engine as hard to make great power, With a solid part combo and a solid tune these numbers come very easy.
Notice only 9.2 PSI boost.
Originally Posted by EFI Tuning View Post
Nice Ted!
Thanks Tim.
Old 01-26-2017, 11:29 AM   #11
SGDM
SGDM's Avatar
Drives: 2016 2SS
Impressive. Well done Ted!
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 01-26-2017, 11:54 AM   #12
JANNETTYRACING
Thank you sir.
Old 01-26-2017, 09:38 PM   #13
steelheadrob
Tactical Garage
steelheadrob's Avatar
Ted,
Do you think you would see similar gains in this set up with pump gas?
steelheadrob is offline   Reply With Quote
Old 01-27-2017, 08:02 AM   #14
JANNETTYRACING
Originally Posted by steelheadrob View Post
Ted,
As you reduce the alcohol content in the fuel the power will be reduced but the mileage will go up.
We made 675 with this exact package on 93 pump gas..
Ted.
