Old 01-14-2017, 06:17 PM   #1
Jonru
Jonru's Avatar
Drives: 2017 zl1
2017 zl1 reving up by itself
last week I was leaving work and was kinda pulling forward slowly working the clutch and giving the car a little throttle and then all of the sudden I had the clutch engage and my foot off the throttle and the car revved up to around 4k rpm by itself ,then yesterday it did the same thing after I picked up my son from school same thing I was working the clutch and pulling forward because of traffic and it did it again and then today did the same thing ,I checked the accelerator pedal its all good there is nothing pushing it or in the way what could be causing this the car only has 1,800 miles?
Jonru is offline   Reply With Quote
Old 01-14-2017, 09:25 PM   #2
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
Probably a bad TPS. If it is doing it enough then take it in and the dealer should be able to fix it.
KLR ZL1 is offline   Reply With Quote
Old 01-15-2017, 09:35 AM   #3
Jonru
Jonru's Avatar
Drives: 2017 zl1
thanks I will
Old 01-15-2017, 09:55 AM   #4
Lashu74
Lashu74
Lashu74's Avatar
Drives: 2017 ZL1
I would think that a bad tps would throw a cel. Do you notice it with rev matching on and off? Definitely take it to dealer asap hopefully they can replicate it, you should try to record it if possible so you have proof. Bummer man hope they get it taken care of for you!
Lashu74 is offline   Reply With Quote
Old 01-15-2017, 09:56 AM   #5
hawk02
Coupe Newbie
hawk02's Avatar
Could you have had rev matching enabled?
Old 01-15-2017, 11:34 AM   #6
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
+1 This would be my guess....
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 01-15-2017, 11:40 AM   #7
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Was the motor warm, or did you jump in and go? My car will accelerate on its own pretty hard if I just hop in and go. I made a topic about it on my SS when I first got the car.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 01-15-2017, 11:51 AM   #8
NB2017ZL1
NB2017ZL1's Avatar
Drives: 2017 ZL1 10 Speed Hyper Blue
+1
2017 ZL1
NB2017ZL1 is offline   Reply With Quote
Old 01-15-2017, 04:05 PM   #9
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Why would rev match cause it to rev up when trying to pull out? Isn't it supposed to match engine revs with the speed of the vehicle (which would be near zero for his instance), the gear you're in, and the gear you're shifting to? The only time it should rev the engine is when downshifting to a lower gear and it should rev it to the RPM that the new gear would need for the current speed. Not saying it's not a possible cause. Just don't understand why it would be.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 01-15-2017, 04:21 PM   #10
Lashu74
Lashu74
Lashu74's Avatar
Drives: 2017 ZL1
Agreed, I was asking because if it was only doing it when it was on maybe the rev matching was malfunctioning?
Old 01-15-2017, 04:22 PM   #11
TJay74
My guess is active rev match causing the problem. But, ARM is off by default at start up from what I read.
Old 01-15-2017, 07:06 PM   #12
17CamaroZL1
Correct. It is off by default and must be turned on.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 01-16-2017, 12:41 PM   #13
TheGC1
TheGC1's Avatar
Drives: 2017 ZL1 Nightfall Gray
Wow, I thought I was crazy when it happened to me... Wow.
I actually had this happen to me at the greatest time a few weeks ago. I had just grabbed my food from the window at a Chik-fil-A drive through, and I pulled forward slightly and then depressed the clutch to slow down stop again... The damn thing revved steadily to 4k-5k or more. I pulled it out of gear and released the clutch and a few other things in that split second it couple seconds. Not sure what finally made it normalize because it was honestly VERY damn stressful. It was a crowded lunch time and they had the employee out directing the loop around the building... So yeah, it was quite the spectacle surrounded by other cars, folks walking around and a handful of employees out there too. Pretty damn embarrassing actually.
It happened that once and hasn't happened since, but I hope it doesn't happen again. Seems like a pretty dangerous thing that the car has the potential to revv like that... Imagine the horrors depending on the scenario... a lot of potential for someone to get hurt, the car to get hurt... Damn.
I would love to know what the issue is here, and I'm certain that this cannot be replicated in front of the dealer's service department...
Now Driving:
2017 Camaro ZL1 A10 | Black
2016 Stingray Z51 A8 | Corvette Racing Yellow
Past Rides:
2017 Camaro ZL1 M6 | Nightfall Gray
2013 Camaro ZL1 M6 #6052| Summit White
TheGC1 is offline   Reply With Quote
Old 01-16-2017, 01:07 PM   #14
KLR ZL1
KLR ZL1's Avatar
Yea imagine if you actually let the clutch out when it happens. Could hit something or someone. Not good at all. It almost sounds like launch control is revving the engine on its own. Hope to see what this is and that they fix it. I'm sure it will be just a reprogram.
