![]() ![]() ![]() ![]() Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
Catch can hooked up wrong???
Hi all,
So, I went to drain my catch can after around 3,000 miles in a year. And.... to my supprise.......nothing. Not a drop! I have a line coming from the back drivers side valve cover to the can, then a line from can to under the throttle body. Am I missing something here? Help please.....
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
No one running a catch can on an L99?
Link to "Search for L99 catch can hook-up" doesn't link back to thread. You'll have to do it on your own.
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I wish I could be more help. I have a 2015 L99 and the pcv is on the -Passenger- side of the engine. I don't have a catch can but that's where I spliced the line for the CAI.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
#5 | |
I hooked it up per the instructions. I don't know. Weird how there is NO oil in it.
#7 |
Do you put yer foot in it very often?
#8 |
I don't rag on it. But, I do drive spirited when I do drive it. I only put about 2,500 miles on it in a year.
#9 |
![]() Join Date: Jun 2014
On your drain open the valve, if there is vacume when you put your finger on it, it is hooked up correctly, if not you have it hooked up wrong, if I remember correctly
Sent from my Nexus 10 using Tapatalk |
#10 |
![]() Drives: 2015 camaro ss Join Date: May 2016
AFQjCNHBgMnJ83F9hYT8qUVePGgxmb43DA&sig2=S2MrC2IDPc P8uUm6ahdbuw
#11 |
![]() ![]() Drives: T Join Date: Mar 2015
The way mine is hooked up is,
there is a valve cover nipple on the passenger side valve cover towards the front of the car sort of near the oil fill cap it comes out a bit sideways. that line goes to my Catch can and a line from my catch can goes to the nipple feed on the intake manifold. The fitting on the driver side rear i have hooked up to a breather filter separately. This is how i was instructed by Mighty Mouse to run it since L99 does not have a breather pipe coming from the Intake valley plate, under the intake manifold. This has worked for me i see a sight glass and can see oil. |
#12 |
Look up elite engineering instructions for l99. That's what I used to install.
#13 | |
#14 |
