01-04-2017, 09:11 AM | #1 |
Drives: 2016 SS 6 Spd Join Date: Jul 2009
Camaro V6 W/ Dual Mode Exhaust (NPP) Borla Rear Section Exhaust ATAK 11931
2016-2017 Camaro V6 W/ Dual Mode Exhaust (NPP) Borla Rear Section Exhaust ATAK $1565.99
6th Gen Camaro BORLA ATAK - The most aggressive of the Borla Camaro Exhaust systems. If you're looking to increase the volume of your 6th Gen Camaros exhaust, while also improving the exhaust tone and HP and Torque performance across the RPM range, then a Cat-Back exhaust is perfect for you Designed using Borla's Acoustically Tuned Applied Kinetic technology, this ATAK exhaust will provide your 6th Gen Camaro with a powerful and aggressive racing exhaust tone that will truly set it apart. This improved tone and increased volume does not come with any sort of compromise either--the ATAK will provide you class- leading performance gains, production quality, and minimal cabin drone! So, again, if you're looking to improve the overall driveability and enjoyment of your 6th Gen Camaro, look no further than this incredible ATAK Exhaust from Borla! Designed using Borla's Acoustically Tuned Applied Kinetic technology, this ATAK exhaust will provide your 6th Gen Camaro with a powerful and aggressive racing exhaust tone that will truly set it apart. This improved tone and increased volume doesn't come with any sort of compromise either--the ATAK will provide you class- leading performance gains, production quality, and minimal cabin drone! So, again, if you're looking to improve the overall driveability and enjoyment of your 6th Gen Camaro, look no further than this incredible ATAK Exhaust from Borla! This system should be used with vehicles that do not have NPP. The AFM valves are still used in this system. ** BORLAŽ's 6th Gen Camaro rear section exhaust systems are covered under our Million-Mile Warranty for non-moving parts, the exhaust valves are warrantied for 3 years. Failures of original equipment AFM and NPP actuators are not covered by the BorlaŽ warranty Application: 2016-2017 Camaro V6 with Dual Mode Exhaust https://www.rpidesigns.com/shop/item...-exhaust-atak/ |
10-13-2018, 03:36 PM | #2 |
10-30-2019, 02:12 PM | #3 |
2016-2018 Camaro V6 W/ Dual Mode Exhaust (NPP) Borla Rear Section Exhaust ATAK $1565.99
